Old 03-04-2019, 07:04 AM   #1
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
Outside Air Temperature Reading
Hi all, I disconnected my battery yesterday to do a couple things to the interior of my car. I connected it back when I was done and left it alone for the night. Noticed on my way to work this morning that my outside air temperature reading isn’t showing on my radio or HUD anymore. I didn’t do anything to have the sensor fall off or anything. What y’all think could have happened?
SSNYSTR is offline   Reply With Quote
Old 03-04-2019, 08:12 AM   #2
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
It may be my only complaint about the car. (aside from AFM!) Though mine works, it’s rarely ever even been close to accurate. Original was replaced. Same dealeo...Oh well.
Moto-Mojo is offline   Reply With Quote
Old 03-04-2019, 10:10 AM   #3
SSNYSTR
SSNYSTR's Avatar
Mine has worked just fine before yesterday. I’ll have to try to find it to see if it’s still in place.
Old 03-04-2019, 10:18 AM   #4
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Just curious, where is the sensor located?
SlingShot is offline   Reply With Quote
Old 03-04-2019, 10:53 AM   #5
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
Mine will work fine for days then for a week get stuck on one number. Drives me nuts. i think its under the grill. I tried disconnecting it and it made no difference disconnected.
JD555 is offline   Reply With Quote
Old 03-04-2019, 12:58 PM   #6
Sozo
Sozo's Avatar
Drives: 2015 Comm. M6 2SS convertible
Just a thought but maybe unhooking the battery reset some preferences in your system ..maybe there is one to show or not show the Temp ..im not familiar with your year but I know my 2ss has a lot of setting in the radio menus for some crazy stuff
Sozo is offline   Reply With Quote
Old 03-04-2019, 04:59 PM   #7
JD555
JD555's Avatar
My battery just went dead overnight this weekend. Ill keep an eye on the temp and see if its reset. I know it fixed my mirror onstar buttons. They have been off for a year now they are lite up again. I never had so many electrical quirks in a car before with things getting stuck.
Old 03-06-2019, 11:56 AM   #8
SSNYSTR
SSNYSTR's Avatar
Sorry that I’m just getting back to this, but for some reason, it had come back on by itself. It’s been on ever since.
The sensor is between the passenger headlight and radiator behind the grill.
Old 03-06-2019, 02:24 PM   #9
camguynj
camguynj's Avatar
If quirky stuff like this happens to our cars what the hell is going to happen to e-cars when their battery dies Dealers are gonna make a fortune.
Old 03-06-2019, 04:32 PM   #10
SSeniorMoment
Drives: 2010 2SS/RS LS3 A6 IOM
The temp sensor on the Camaro works fine, reads 77F as I write, same as the weather station. Replaced the battery last week, it lasted for a very long time.
SSeniorMoment is offline   Reply With Quote
Old 03-06-2019, 06:01 PM   #11
Foxfire15
Drives: 2015 2LT/RS BVM
Mine works fine....ish. If it's real hot or real cold (for here anyway) it's usually off by 3-5 degrees, or there's so much heat coming off the asphalt that it pegs out on me. I've accepted that it's "good enough"
Foxfire15 is offline   Reply With Quote
Old 03-07-2019, 03:28 AM   #12
Gordo-D
Gordo-D's Avatar
Drives: 2015 Camaro 2SS
Compared to my other two cars, the Camaro is a few degrees out, they both match exactly.
Gordo-D is offline   Reply With Quote
Old 03-07-2019, 05:55 AM   #13
Dogmeat
Dogmeat's Avatar
Drives: 2011 RS
You "think" it's under the grill, but you "tried disconnecting it"......make up yer mind....You must KNOW where it is IF you "tried" disconnecting it.....
One post it states that the sensor is between the pass. headlight and radiator...
Proud Owner Of '11 Camaro
Dogmeat is offline   Reply With Quote
Old 03-07-2019, 10:17 AM   #14
JD555
JD555's Avatar
Pretty sure its right side under the front grill but its been about 3 years. It was a tight squeeze
