01-21-2019, 07:05 AM | #1 |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
ZL1 - Trailer Tiedown Strap Options
Just picked up an Aluma 8220Tilt and, I am pondering the strapping options. Whatever I get will come from MACs, but, the options are basically 1) Under car frame points via ZL1 AddOn items 2) Through the wheel 3) Over tire top and secure with eTrack.
It looks like Option#1, the straps will push up against the front splitter and rear may straddle muffler area? Option#2 using MACs or any other similar will not reach the front D-Rings w/o splitter contact... may have to use side stake pockets. Positive being "X" strapping in the rear for lateral protection.Option#3 looks cleanest but, not 100% sure about lateral movement. Positive being car suspension does the work and no body/wheel contact. At this moment I am swaying towards #3 Over-The-Tire.... Thoughts, options, pics? (Thanks in advance)
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 Last edited by kaamacat; 01-21-2019 at 11:25 AM. |
01-21-2019, 08:17 AM | #2 |
BAMF SS
I have option 1
I think option 1 sucks. It compresses the suspension, which I do not like. You can't really cross the rears, which I do not like. The nuts on the rear like to come loose (one of these days I will put some Loctite on them). The rear ones also spin, which they aren't supposed to, which I do not like I want option 3
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
01-21-2019, 08:36 AM | #3 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Etrack with wheel straps and call it a day. I have pulled thousands of miles with this set up with the cruise set a 85mph and never had a strap issue or the car move any.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap Last edited by ICTsccaCamaro; 01-21-2019 at 08:59 AM. |
01-21-2019, 09:44 AM | #4 |
Excellent and thanks. I was looking for a real-world pic and use for the e-track with our car. I also saw that Ericsson has a e-Chock that might serve as a nice addition. Again, thank you!
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
01-21-2019, 10:44 AM | #5 |
Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
Yep, that's the way!
Instagram: MattZ_L1 Vengeance Racing Built
01-21-2019, 12:34 PM | #6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
One more for #3.
01-21-2019, 12:37 PM | #7 | |
ITCRNRS
http://www.ericksonmfg.com/product/m...e-chock%C2%AE/
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
01-21-2019, 04:52 PM | #8 |
I use option 1 and cross the straps in the rear. Yes, the retaining nut has become loose once. The car is easy to strap and never moves so what is the big deal? Over the tire straps are likely more secure but is there any true "advantage"? I am happy towing with option 1.
01-21-2019, 06:00 PM | #9 |
Drives: 2018 Silver ZL1 1LE Join Date: Feb 2018
I also Use e-track and over wheel set-up. I am super happy with it.
01-21-2019, 06:09 PM | #10 |
CamaroFans.com
I have never seen E-Track on aluminum trailers. Is there a reason for that or I just haven't seen it done?
I plan to do Option 3 for the front and Option 1 for the rear. |
01-21-2019, 08:06 PM | #11 | |
I just picked up my trailer last week, and this coming weekend will size-up where the eTrack might go (think I've measured about 61.5" avg between front and rear tire center open groove area. I would do thru-bolts on the track unless where I'd make the holes is directly over a support beam I can not access, or on the corner of a beam. We will see.
BobR
01-22-2019, 12:50 AM | #12 | |
ITCRNRS
01-22-2019, 07:28 AM | #13 |
My same thoughts as-well. Let the car take some of the small jolts that the trailer did not absorb.
BobR
01-22-2019, 07:44 AM | #14 |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
Congrats on the new trailer, OP!
I use Macs thru the wheels and they work fantastic. COTA is 17hrs one way, Road Atlanta is 12hrs, never a problem and the car never moves. I cross the fronts and that allows for no contact with the splitter, and don't cross the rears as the D-rings are actually inboard the wheels a bit so the car can't move laterally. Really simple, fast to do, and the Macs straps are the bomb.
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
