11-04-2018, 11:38 PM | #1 |
Stigs Bahraini Cousin
Driver side door trim scratch
I have accidentally scratched the door cover/panel on the driver side. is there anyway to repair the scratch or make it less obvious? This is just my second week owning the car
Attached 2 photos of the scratch
2015 CAMARO 1LE
11-05-2018, 02:00 AM | #2 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
wtf did you do to it? You'd have to get a new door card
2011 2SS/RS built 8/24/10
11-05-2018, 09:57 AM | #3 |
Let me guess, opened the car door with the key extended?
Sorry pal, the only thing you can do is replace the parts.
GHOST · 2SSRS
Order Date: March 28, 2009 // DoB: June 19, 2009 // Arrival Date: July 2, 2009 Current Modifications:
11-05-2018, 10:14 AM | #4 |
No, i had a hand rest there and pulled it back so the bottom part of it scratched the panel. I found a shop here that can fix it. I will update this post of this scratch is fixable.
2015 CAMARO 1LE
11-05-2018, 11:09 AM | #5 |
Interested in procedure and results as I’ve got a rub mark from something? T that removed some of the finish on the panel.
11-05-2018, 12:07 PM | #6 | |
If i am not mistaken, the shop will sand the plastic, polish it and then apply a clear coat over it. I will ask them though on what they did to repair it once they are done from it.
2015 CAMARO 1LE
11-05-2018, 04:09 PM | #7 |
scratch
what is a hand rest?
11-05-2018, 04:38 PM | #8 |
It's something locally made that you put on the door to use as a hand rest and has storage space. I threw it away
2015 CAMARO 1LE
11-12-2018, 12:08 PM | #9 | |
They wet sanded the scratch and polished it once the scratch was gone.
2015 CAMARO 1LE
11-12-2018, 02:11 PM | #10 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Pics of the fix?
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-13-2018, 04:28 AM | #11 |
I attached a photogl after the repair.
Note: the black plastic door trim had another procedure to repair which involves painting.
2015 CAMARO 1LE
