11-02-2018, 09:48 AM | #1 |
Big B
Drives: 2016 2SS Summit White Join Date: Aug 2009
how to keep stock Black rims clean
So I just recently picked up 2016 2SS with black wheels and I am wondering how to keep them shiny. Is there a product that I can buy to put on them to keep them clean or at least make it easier to wipe off?
2016 2SS,NPP exhauset, A8, Black and White interior, black rims, black center stripe. |
11-02-2018, 09:51 AM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Read the link in my signature about wheels. Still the easiest way I've found to keep them clean
11-02-2018, 10:28 AM | #3 |
Big B
Ok thank you sir
11-02-2018, 11:03 AM | #4 |
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
I also put my DA polisher to them (factory black 5 spoke) using a 4 inch pad and they came out shiny, and I also changed my brake pads to the power stop pads and no more brownish looking wheels.
11-02-2018, 11:20 AM | #5 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
You MUST go to ceramic pads although the stopping power takes a hit.
Coat the wheels and calipers with a ceramic coating and follow Glens advice,.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
11-02-2018, 11:28 AM | #6 |
^ what he said. Change ceramic pads, you lose braking power but it's still more then enough unless you road course the car. Then ceramic coat the wheels.
2016 NFG 1SS A8
11-04-2018, 10:18 AM | #7 |
Drives: 2017 1LE Join Date: Nov 2017
Glenn: excellent overview. Hell, I can even follow it.
Question: have you tried Zaino tire stuff? I have a bottle of the Armor All you exampled; however, find the Zaino far superior. Yea, I'm partial...however... Chris
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
11-04-2018, 10:50 AM | #8 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I had my wheels ceramic coated with they did my car. While it doesn't keep the brake dust from collecting on the wheels, it does make it come off very easily and keeps the brake dust from etching into the wheels themselves.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
11-04-2018, 11:59 AM | #9 |
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Ceramic brake pads, it’s truly the only way to avoid brake dust.
11-05-2018, 04:41 PM | #10 |
Drives: 2017 Camaro SS 1970 chevelle SS Join Date: Oct 2016
Anyone care to recommend a good set of carbon ceramic pads for the SS four pistons?
11-05-2018, 06:26 PM | #11 |
Drives: 2017 Camaro SS 1LE Join Date: Nov 2015
I just got mines replace on a ss 1le got the Power Stop Z26, FOR AN SS, see link below.
Power Stop K7226-26 Front and Rear Z26 Street Warrior Brake Kit https://www.powerstop.com/product/po...ss=SS%20Models |
11-06-2018, 07:14 PM | #12 |
War Horse Pilot
Ceramic coating or Chemical Guys wheel wax also works good. I ceramic coated mine and the wifes, but have used the wheel wax with good results.
11-07-2018, 03:24 PM | #13 |
Drives: 2016 Camaro 2SS Join Date: Sep 2016
Be sure you change the rotors as well or at least re surface them. I made the mistake of just swapping out the pads and my car squeaks terribly now for the first few stops. It's rather embarrassing.
11-08-2018, 10:02 AM | #14 |
I didn't have that problem but I changed the pads(PS Z26) when the car had 1500 miles. I just used a scratch cloth and brake clean on the rotors.
2016 NFG 1SS A8
