11-01-2018, 12:29 PM | #1 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
valve covers
Are there any Gm/Chevy valve covers for the LS that will bolt on and cover the coils?
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
11-01-2018, 06:32 PM | #2 |
Check out Holley, I think they have some for what you are looking for.
11-01-2018, 07:00 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
11-02-2018, 06:47 AM | #4 | |
Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
None that I have found, unless you want cheap plastic bolt over covers. There are a few different options for valve covers, Holley and Proform are the most popular. But those only have different mounts for the coils, they do not cover them. MSD makes some plates that bolt over the coils, but they look pretty tacky in my opinion. If you really want to clean up the engine bay, pick up a coil relocation kit. They come with all the wiring, custom cut plug wires and mounts, you can put the coils where ever you want.
2018 ZL1 2015 1SS 1LE Stock...ish |
11-02-2018, 09:26 AM | #5 | |
thanks
11-02-2018, 04:37 PM | #6 |
Check out Michigan Motorsports.
11-02-2018, 05:07 PM | #7 |
covers
