10-22-2018, 11:36 PM | #1 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Trunk won’t open
Car threw a nice little trick at me a few days ago. The truck clicks when I use the key fob or when I push the button on the door...but it will not unlock/unlatch.
I messed with it pushing down pretty hard...nothing. I only found out because I went to take the top down and got the message that the divider is not attached...so, I popped the trunk to fix it...except it didn’t work. I assume the only option is to remove the back seat and go in to use the emergency latch in the trunk. Of course that will really suck with the top up. Any other options?
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
10-22-2018, 11:50 PM | #2 |
Drives: 2019 Plum Crazy Scat Pack Charger Join Date: Jul 2018
Thnk you are pretty well stuck on that.
10-23-2018, 05:33 AM | #3 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
Well, that’s a bummer. If you take the seat out, what you’ll run into is all of the electronic components for the top. It’s held in place with rigid styrofoam.
I think you can get a better idea of what you’re in for by searching the stereo upgrade section for a convertible. I could have sworn I saw a White ZL1 torn apart. |
10-23-2018, 05:39 AM | #4 | |
Thank you Al Oppenheiser!
Need you to crawl through the back seat, dear... yep just like that.
10-23-2018, 06:11 AM | #5 |
10-23-2018, 06:30 AM | #6 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
There is a keyhole by the back seats to manually unlatch the trunk. They even give you a plastic 'wrench' to give you more leverage on the key. Check the manual.
10-23-2018, 06:45 AM | #7 |
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
Happened to me twice a few months ago. I pushed down on the trunk and then used the door panel trunk button to pop it again. That resolved it. Sounds like you've already pushed down on it. Try again and follow with the door panel trunk release button instead of the touchpad or keyfob.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
10-23-2018, 04:57 PM | #8 | |
Closed the trunk and stuck again. Good news is, I can get stuff out and get my top working, but will need to go to dealership for the fix.
10-24-2018, 03:58 AM | #9 |
Drives: 2016 Camaro Convertible 2SS Join Date: Jan 2016
locked myself out the first year I put the car up for the winter and had to use the manual entry but have not had this happen to me YET! Please let us know what the dealer says.
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85 |
10-24-2018, 07:51 AM | #10 |
Drives: 2022 2SS Vert in Wild Cherry Tint Join Date: Oct 2018
Same thing here. Used keyhole behind driver rear seat to open.
10-25-2018, 07:16 AM | #11 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
10-25-2018, 08:00 AM | #12 |
I did let her know that was the recommendation from the forum, so we are going to give that a try tomorrow for date night. . .we are going to work on the car together.
10-25-2018, 12:36 PM | #13 |
(could'nt resist putting this emoji to use)
10-28-2018, 07:09 PM | #14 |
I will take the car to the dealership soon so that I can have them check it. I was kind of hoping after I opened it the problem would go away...no luck.
