Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 10-05-2018, 12:29 PM   #1
Alexia
Drives: SS
Brake Pedal Position Sensor?
I am trying to fix an issue with the brake lights staying on constantly.(2011 SS) Is there not a brake pedal switch? I found a brake pedal position sensor, but I thought that was for ABS/traction control reasons. Does it handle turning on the brake lights through the BCM as well?
Thanks!
Alexia is offline   Reply With Quote
Old 10-05-2018, 07:14 PM   #2
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Brake pedal position switch is what your looking for. It sends a signal to the BCM and the BCM turns on the brake lights. It has no direct control over turning on the brake lights like the old brake light switch. The yellow wire is the brake light signal wire to the BCM.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 10-05-2018, 07:23 PM   #3
Alexia
Drives: SS
Thank you! Reading up I guess I have to potentially get it calibrated as well, but hopefully not.
Old 10-05-2018, 07:45 PM   #4
SSMickey
SSMickey's Avatar
No calibration needed if you replace the BPPS. The BBPS sends a voltage signal to the BCM when you step on the brake pedal. If the sensor is messed up and is constantly sending out a signal the BCM will keep the lights on. The other, less likely option is the BCM is messed up. If you end up replacing that, it has to be programed and set up. Not a DIY job. What happens to the brake lights if you unplug the BPPS?
