Old 09-21-2018, 01:38 AM   #1
onebadjon
Drives: 2017 Stingray Convertible
Question Key Fob - convertible top
have a 2017 C7 Stingray, KeyFob will not operate the convertible top. have press the unlock button, then press & hold the top button, nothing happens. The button on the dash works, no problems there. Need help , thanks - John
onebadjon is offline   Reply With Quote
Old 09-21-2018, 07:37 AM   #2
h422694
h422694's Avatar
You have 2 keyfobs. Do both of them have the same problem? If not change battery in one that does not work correctly.
h422694 is offline   Reply With Quote
Old 09-21-2018, 03:01 PM   #3
onebadjon
thank you
Old 04-25-2019, 01:28 AM   #4
bertie
Drives: 2001 Camaro
Have you ever found the cause of the issue?
bertie is offline   Reply With Quote
Old 06-04-2019, 12:34 AM   #5
rdanzel
Drives: 2010
Try disconnecting your car's battery and see if it will reboot including the top control system.
rdanzel is offline   Reply With Quote
