09-20-2018, 12:12 PM | #1 |
Drives: Dusk SE Join Date: Jun 2014
strange sound
This is just weird. so I go to the garage to take out the trash and as I walk by my car I hear a pop noise. car has been parked all night. this was not the only time that me or someone else (wife) has heard it do that.
Im thinking something is relaxing after being hot but I have heard it when the car hasn't even been driven in a couple of days. any ideas?
Daily Drives Dusk SE 2SS/RS
09-20-2018, 12:59 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Cat? I've known cats to sleep in and around parked cars.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
09-20-2018, 01:51 PM | #3 |
Drives: 2014 2SS blue Join Date: Jun 2016
I used to hear sharp pops when driving my truck and the same sound driving my Camaro. Turned out to be the plastic water bottle setting in the console. The sun would expand the air in the bottle and then pop the wrinkles out. Unnerving.
09-20-2018, 02:44 PM | #4 |
From the rear/trunk area of the car? The EVAP systems run self check periodically after the vehicle has been sitting a while, and have valves that click on and off, some cars can be rather loud, maybe this is the noise you noticed?
09-21-2018, 02:29 AM | #5 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
I had the popping from the trunk area on my old 2010, usually after just switching it off, not heard it on the 2015 as yet.
