#1 |
How often should I change Mobile 1?
Hi, I have a 2012 Camaro SS with 3900 miles on it. I last changed the oil in July 2016 with 3000 miles and put Mobile 1 in her, the reason being I do not drive the car much and did not want to put in any dyno oil that would accept moisture. My question is in terms of time how often should I change the oil being it is synthetic Mobile 1?
#2 |
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
I would recommend changing it once a year regardless of mileage. After a year it gets moisture and contamination... should be changed imo
603 h.p. 495 ft lbs tq. |
#3 |
Drives: 2010 Camaro Join Date: May 2014
#4 |
Drives: 2015 Camaro Join Date: Aug 2018
Yeah, even with synthetic you have to change it once a year regardless of mileage. That's for the warranty. If the warranty is gone, then I don't think two years is really that bad. The moisture thing might bother me though. So, I'd do it every year. Better safe than sorry I guess.
#5 |
Instagram: Sangstah
I use Mobil 1 and change every 5k miles.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
#6 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
I agree - At least once a year. You need to drive it! Letting it sit is more harmful than not driving it. Rubber seals and O-rings will harden when they sit for a long time.
#7 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
I change my at least one a year or 5k which ever comes first.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop Rx Catch Can;Rx Breather;Roto-Fab Washer Container VMax Ported RJT Throttle Body XSPower Headers and XSPower 3" Exhaust System Elite Engineering Tunnel Brace, Gorilla Wheel Lock System; Bear Rotors, Hawk HPS Tinted Windows 35%;EFILive Tune |
