08-07-2018, 11:24 AM | #1 |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
Winter Tire Square Setup
Anyone run a smaller square set up on their 1LE? I plan to daily this in Michigan.
I found this set on tire rack for a good price. It doesnt show up when I select 2SS 1LE Track pack. But it does show up when I search 2SS with ZL1 Brembo Brake kit. Would I need spacers with these or will I be able to put them on with no rub or issues? They come in 18's or 19's. Thoughts? |
08-07-2018, 12:57 PM | #2 |
^Name^ | Things I Say -->
Drives: 2016 2SS Convertible, Hyper Blue Join Date: Oct 2016
I have 18x8 20 offset with the same size tires, they fit absolutely perfectly. You'll need to check the offset of those wheels, then figure out how they compare. I don't think there's a whole lot of room on the outside of the tire with my setup.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator Based on a few inputs, I think if the offset of 8.5" wide wheels is between 20 and 26, you'd probably be fine. Any less and who knows. Some googling got me this link which leads me to believe the offset of these wheels is 15mm. I think they'll rub. Check out the pic of my setup below. The calculator says the wheels in your post will poke 11mm further out. |
08-07-2018, 01:08 PM | #3 | |
Do you have a link or pics of the rims you are running with the tires? |
08-07-2018, 01:12 PM | #4 |
Drives: 2018 Camaro 1LE Summit White Join Date: Oct 2017
So,,,, We change the tires and wheels all around the 4 corners of our 1LE.
What does this do for Alignment? Is our car tracking the road correctly? Do the Techs at your Chevy Dealer even care? Do they even know? How are the tires going to wear? Does it even matter? This is what I would like to know. I phoned my Dealer shortly after I purchased my Car. I phoned and asked if could purchase all season rubber for my 1LE so I could ride her past October. Totally confused. They continuously picked up their playbook and read off the exact same summer tires that came with my Car. |
08-07-2018, 01:16 PM | #5 |
Sure, I've attached below. They're cheapie Drag wheels. You could do some measuring - those wheels might fit. Stock 8.5 fronts are 25 offset, so the setup you describe would be 10mm further outboard. Measure it up, maybe it'll work.
08-07-2018, 01:19 PM | #6 |
These ones are the exact same width and offset of the stock wheels, if you're into this sort of thing. I'm not, but they're cheap at least.
https://www.tirerack.com/wheels/Whee...embo+Brake+Kit |
08-08-2018, 02:33 PM | #7 |
Drives: 2017 1LE Join Date: Jul 2016
I daily mine as well in Michigan and went with a cheap set of Drag DR37 wheels from discount tire in 19x9.5 with 285mm wheels and required no spacers. Previously I had 245s and personally would never go back to a smaller tire. The handling and dry grip just wasn't what I wanted it to be. I used this calculator: https://tiresize.com/wheel-offset-calculator/ to calculate the aftermarket wheels backspacing/offset I needed compared to stock and it worked perfectly.
17 Summit White SS 1LE PDR / Borla S type Catback / XPEL Ultimate PPF
08-08-2018, 02:59 PM | #8 | |
08-08-2018, 03:30 PM | #9 | |
https://www.discounttire.com/buy-whe...-dr-37/p/50127 Tires were Michelin Alpin Sport, cant remember the profile off the top of my head but i think they were 285/35s (way better than the Blizzaks on my wife's charger IMO) http://i1378.photobucket.com/albums/...psswwg12lp.jpg http://i1378.photobucket.com/albums/...psfpghdkdh.jpg
08-08-2018, 03:31 PM | #10 |
Drives: 2018 2SS 1LE in Nightfall Gray Join Date: Jul 2018
So on this topic, I don't need true winter tires here in Maryland, but do need all-seasons for the cold months. I was thinking of putting Continental DWS06 tires all the way around on the SS 1LE rims -- OEM size 285/30/20 on the fronts and 315/35/20 on the rears. The rear tires would be 10mm wider and just a hair taller.
Think this would cause any significant issues? Last edited by JD_; 08-08-2018 at 03:32 PM. Reason: typo |
08-08-2018, 03:47 PM | #11 | |
08-08-2018, 04:00 PM | #12 | |
Yeah, just took a look at willitfit and i think it would be too close for comfort. Another site seems to suggest that a square set of 285/30/20 would fit front and rear. |
08-08-2018, 04:16 PM | #13 | |
Drives: 18 1SS/1LE Join Date: Jun 2018
08-08-2018, 04:23 PM | #14 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The whole winter tire thing should be a sticky with all these threads merged.
Here's my winter setup: Verde from Tire Rack, 19x8.5 et15 front and rear with Pirelli Sottozero 3's in 245/45-19. Nice and narrow for cutting through the snow, but definitely missing a bunch of dry grip. Weekend by Ryephile, on Flickr
