07-17-2018, 07:45 AM | #1 |
Drives: 2018 ZL1, Garnet Red Tintoat, 6spd Join Date: Feb 2018
Manual 1-4 shifting
Anybody else with the manual trans as sick and tired of the second gear lock out when it tries prompting a 1-4 shift as I am? Other than the thigh bolsters on the seats being really tight which isn’t horrible, just could be a tad wider but the second gear lock out is actually irritating to me. Is there any simple solution to disabling it?
Fuel economy isn’t anywhere near, let alone on my list of priorities. |
07-17-2018, 07:51 AM | #2 |
Drives: 2018 Black ZL1, 1977 Yellow 308GTB Join Date: Jul 2017
Just take your revs a little higher in first and it will not happen. I have only seen it pop up 2 maybe 3 times and only when I have been coasting very slowly in first.
07-17-2018, 08:01 AM | #3 | |
American Gearhead!!
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor Join Date: Mar 2013
https://www.phastekperformance.com/2...SAAEgJmwfD_BwE |
07-17-2018, 08:01 AM | #4 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Shift from first to second above 19 mph and you'll never experience the second gear lock out.
08-31-2018, 09:36 AM | #5 |
Thanks for the replies fellas. Throttle input is of course the simplest solution not always possible depending on traffic conditions. I did see recently a few tuners that can disable it as stated above. Will definitely be doing that, the permanent solution.
08-31-2018, 09:54 AM | #6 |
Drives: 2018 Camaro ZL1 Nightfall Grey Join Date: Jun 2015
Just shift at a slightly higher rpm, or
Double clutch, defeats it, or Buy the skip,shift eliminator It’s a ridiculous feature btw
1100 - 10/28/17 Ordered
1100 - 02/02/18 cancelled, Re-ordered from BeckyD 1100 - 02/02/18 | 3400 - 02/14/18 TPW 2/19 2000 - 02/06/18 | 4300 - 02/20/18 Built 3000 - 02/07/18 | 5000 - 03/08/18 At Dealer 3100 - 02/09/18 | Delivered |
08-31-2018, 10:25 AM | #7 |
As you mentioned - it can be turned off permanently in the tune or you can install the eliminator cable. I did the tune out on my fifth gen and that was great. For my sixth gen I just shift above 19 mph or if I forget and hit the lockout i just shift to third. It will let you do that and third doesn't lug the engine like fourth.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
08-31-2018, 11:12 AM | #8 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
When GM started the 1 to 4 shift on 6spds way back when.......Something I tried and worked back in 1996 with my 6spd Trans-Am was when I wasn't paying attention driving around town so when I felt a 2nd gear lock out, instead of going to 4th I tried going straight to 3rd instead, it let me do it and it didn't bog the car down as bad as going into 4th. It's something I've been doing ever since.
08-31-2018, 11:21 AM | #9 | ||
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
08-31-2018, 11:27 AM | #10 |
雪の玉
It worked on both of my 5th gen M6's...Not sure about 6th gen, I suppose it should..........For the short time I had the '17ZL1 it was never an issue
08-31-2018, 11:51 AM | #11 |
C'mon- really?
You had a ZL1 and went to the SS? Just curious as to why? Was there something about the ZL1 you did not like? I trade a lot/often too so I can understand!
Steve
08-31-2018, 01:15 PM | #12 |
雪の玉
I went back after being without a Camaro for 7 months, it happed to be a SS; a v6 RS would've been fine too....ZL1 was awesome, but I can have my Silverado 4x4 and Camaro for what the ZL1 cost.
08-31-2018, 01:19 PM | #13 |
Drives: 2019 ZL-1 Join Date: Feb 2009
First to third... works well!!!!
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD |
08-31-2018, 02:45 PM | #14 |
FWIW, using a tune to disable it will void your warranty.
Installing the Skip Shift adapter cable is easy, quick, and only costs around $15-20 or so. Skip Shift is designed to only engage under certain conditions, a combination of speed and throttle position. Shifting at a higher rpm will prevent it from engaging. Even if on rare occasions it kicks in on my ZL1, I discovered that all you have to do is shift to neutral for a second, pause, then slip it into second. Piece of cake. Pick a solution for you. |
