06-21-2018, 10:35 PM | #1 |
Ridetech Coilovers installed
Had my favorite suspension and all around race shop do the install and alignment for me today - SoulSpeed in Austin.
If you're in this area and need help with your race / track or street car these guys are the real deal. Racers and master mechanics. Anyway enough about them (only affiliation is that I've been a customer for 10 years) While it's too soon to give my impressions of the Ridetechs, as I've only had a dozen miles on them and no track time, I'll give my initial first impression. I live on rural backroads with some nice twisty sections so I got a little taste in familiar settings. I'm impressed. I was impressed with the 1LE suspension, but this is worlds better. Now I will say that...perhaps the alignment settings are accounting for a lot of that improvement. They gave it a moderately aggressive street alignment. Front camber is -2.2 -2.2 Toe is 0 Rear camber is -1.6 -1.6 Toe is practically 0 (0.16) With the stock suspension in certain corners it was very easy to get a bit of slip, a little wiggle in the rear as I carry speed and apply some throttle. Same corners now with the new suspension and alignment are completely planted and controlled, at a faster pace. Now I know this is no track, and I was no where near what I would push on the track, but I know the car and the roads well enough to get an idea where it wants to be a little loose, and a little tight. Next test will be a very tight decreasing radius turn that is very easy to get push at a moderate pace with the stock suspension. I'll give that a whirl tomorrow and see how it feels. Tires are Michelin PS 4S in stock 1LE sizes on stock 1LE wheels. Comfort: So far so surprisingly comfortable. I left the settings where the shop put them, so far on the street I don't feel a need to change it but I will to test a bit. I'll do more of that at the track of course. They do feel like more spring rate than stock and you get a little bit of that stiff spring bounce, but it's very well controlled and I have yet to experience any harshness. It seems the shock absorbers/dampers are quite a bit better than OEM (to be expected but not always the case). The OEM I think have more rebound baked in, which isn't always the right answer. And course, I love the way it looks now, lowered just about an inch. Doesn't look so much like a 4 wheeler now. Give me a few months with them, a track day or two and maybe the afterglow will fade a little If anybody wants 1LE shocks (springs too sure, but they're the same as SS springs) let me know. I'll put them up for sale soon. Also have a used set of z/28 springs and multimatics I bought from a member here that I probably won't feel the need to use either.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR CTSV/ZL1 front calipers/rotors + G-Loc Forgestar CF-5 19x11 |
06-21-2018, 10:51 PM | #2 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
Get some pics up. We carry Ridetech coilovers. Great set ups for sure.
06-21-2018, 11:39 PM | #3 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
08-27-2021, 06:24 PM | #4 |
Drives: 2014 Camaro 1SS (A6 Ashen Gray) Join Date: Sep 2019
My apologies for reviving this thread. I've got the same coilovers and tires. Overall, they're one of my favorite upgrades thus far! It's insane how much they transformed the car's handling while maintaining a stock comfort level (if desired).
However, I've run into some things lately with them. The driver's side rear began to squeak and it's been getting a bit worse. I've also had clunking in the front on both sides. Soulspeed (small world, eh?) fixed the clunk on the front driver's side. It was related to the bracket that connects the end link to the strut. However, the other issues appeared maybe 1-2 months after the appointment. Have you ever run into these issues? To be fair, some friends helped install the coilovers (not Soulspeed). I've read that aftermarket coilovers sometimes take more maintenance than stock equipment, but these were installed less than a year ago. D: EDIT: I had subframe bushings and sway bars installed at Soulspeed. During the appointment, they found the cause of the two suspension issues. The front endlinks had become loose on both sides, to which the shop applied loctite and retightened. The noise in the rear appears to be related to "spherical upper spindle bushings", which will have to be resolved once the necessary parts are acquired.
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, Continental ECS 02 tires, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back exhaust, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
09-01-2021, 10:40 AM | #5 | |
I didn't have any issues with mine, but I wound up selling the car a few months ago due to a long string of bs with my poorly chosen shop that was handling the engine upgrade. 2 years debacle with no engine in the car I heard some folks had some issues of bending some connecting parts (maybe sway bar link)...sorry vague recollection, read that somewhere on the forums. At least the Fox shock should last a very long time, and of course the hyperco spring as well.
