TireRack
Old 06-12-2018, 06:34 AM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Best Low Dust/Noise Brake Pads
Best Low Dust/Noise Brake Pads? I have an 1LE with Brembos and looking to cut down on the ridiculous brake dust and occasional squeal of the stock pads.
zz430camaro is offline   Reply With Quote
Old 06-12-2018, 07:13 AM   #2
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
You will give up performance
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 06-12-2018, 07:35 AM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
May be another reason you have squeal. I've run OEM pads on the street and track, and have never had squeal. Also, as mentioned, if you go with lower dusting, you'll most likely be giving up on performance. Pads can't perform as well if they don't break down somewhat.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 06-12-2018, 07:40 AM   #4
zz430camaro
Drives: 2015 1LE
I am not concerned about the performance.
Old 06-12-2018, 06:42 PM   #5
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
AKEBONO pads=ZERO Dust. lil'squeaky when you first put them on. The car stops just fine....
Eddiefuzz is offline   Reply With Quote
Old 06-13-2018, 06:19 AM   #6
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
you say that until some stupid driver, not paying attention pulls out in front of you, while your are doing 60 mph. This heavy pig needs some pads to stop it!
I have always had Hawk Ceramic pads and it really cut the dust from the OEM pads and never had issues with noise.
Old 06-13-2018, 06:53 AM   #7
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
PowerStop Z26. Have them on my C7 corvette and they perform every bit as good as stock Brembos, if not better....just ordered a set for my Canaro too. They don't cost much, and eliminate 95% of the dust. Don't listen to the naysayers, it'll be one of the best purchases you ever make for your car.
joeybsyc is offline   Reply With Quote
Old 06-13-2018, 06:41 PM   #8
zz430camaro
Drives: 2015 1LE
Ran out to Summit Racing and picked these up, look like nice pads. Going to pop off the rotors and get them a fresh cut and pop these on. Looking forward to not having to clean these wheels so much, hope they dont squeal.
Old 06-13-2018, 09:35 PM   #9
joeybsyc
joeybsyc's Avatar
You'll love em.
Old 06-14-2018, 05:50 PM   #10
Roasstum1
EbonyCamaro
Roasstum1's Avatar
Drives: Black SS 14
What Joey said.
Roasstum1 is offline   Reply With Quote
Old 06-14-2018, 07:53 PM   #11
camguynj
camguynj's Avatar
Did you cut your rotors with the install?
Old 06-14-2018, 08:49 PM   #12
zz430camaro
Drives: 2015 1LE
I am not sure if he did but i think it would be a good idea for a new set of pads to have a fresh and flat surface to lay on.
Old 06-15-2018, 01:42 PM   #13
xc_SS/RS
Drives: 2010 Camaro SS/RS
i run stoptech street pads and there is less dust that stock. i start to notice the dirty wheels around 2-3 weeks after a wash or so
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
