Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
Old 05-18-2018, 08:51 PM   #1
rorymick
rorymick's Avatar
Drives: 2016 Camaro RS 1LT 2.0L Turbo
Rear bumper cover access from trunk area
Guys I need to mount Anti-laser priority sensors right beside my rear license plate lights and back up camera...
I've removed the trunk liner etc and have my wires ran from the cabin to the trunk area inside. However I don't see how the rear bumper cover or even the harness to the camera or lights goes from inside the cabin to the bumper cover. I need to fish these wires to there.
Anyone have any experience with this area?
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
rorymick is offline   Reply With Quote
Old 05-18-2018, 10:04 PM   #2
Zophix
Zophix's Avatar
Drives: 2016 Camaro 1LT I4 Black
The license plate lights and back up camera run behind the driver side wheel well. So they don't actually go from the trunk to the location they are. If you were trying to get a wire to that location from the trunk, one way you could do it would be to go through where the tail lights are mounted, there are holes there but they are very tight and intended to seal.
I'm not currently with my car so I can't actually see any other locations where this could be done. I'm sure there is another way you could do it though.
Zophix is offline   Reply With Quote
Old 05-18-2018, 10:57 PM   #3
rorymick
rorymick's Avatar
I watched one of lethal Camaro videos of him changing the rear valence. I think that I could likely drill a hole in the sheet metal body right behind the rear bumper cover and install a grommet and then rtv seal the wires passing through. Then fish them into the license plate lights. There's holes in the light housings.
But I'm still all ears and will likely contact lethal Camaro for his opinion.
Old 05-19-2018, 09:39 AM   #4
StPeteHyper2.0
StPeteHyper2.0's Avatar
Drives: '16 Hyper Blue 2.0
Maybe this will help..
StPeteHyper2.0 is offline   Reply With Quote
Old 05-19-2018, 09:44 AM   #5
StPeteHyper2.0
Behind the drivers side rear wheel is the harness to follow. There are a couple plugs next to the sidemarker. If you remain your route in the trunk, you will be drilling thru somewhere.
Old 05-19-2018, 08:38 PM   #6
rorymick
rorymick's Avatar
Those pics and the following the harness outside are a big help. I either re route and get outside the car or wherever that harness route is going...or yeah drill. I'm gonna be back at this on Wednesday so I'll see how it goes!
Old 05-19-2018, 11:41 PM   #7
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Watch the video....
-bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
