05-03-2018, 10:24 PM | #1 |
Sarcasm loading --------
PDR Component part numbers and install
Considering adding PDR to a non-PDR car? regardless of what GM or your dealership says - it can and has been done.
The cost to add the PDR at purchase of the vehicle was about $1400; installing PDR after purchase will cost more unless luck is on your side. Parts will need to be purchased, and some will need replaced with components out of a PDR donor vehicle or purchased new. As more of these cars get totaled out and parted used parts are becoming available. Cost of parts only to install PDR is around $2100 with a used recorder, camera and display.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD Last edited by nighttowl; 11-03-2021 at 11:48 AM. |
05-04-2018, 07:22 AM | #2 |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
Wiring harness might need modifying / creating. I've found that if the car wasn't optioned with it, the wires don't exist. Not sure on the PDR... but it is the case on several other options.
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
05-04-2018, 07:27 AM | #3 |
Here's some of those diagrams
05-04-2018, 08:11 AM | #4 | |
my Nav unit was already updated with the PDR, it may be plug and play - I dont know. I emailed gen5diy about what else is needed, but they havent gotten back to me yet. the dash has 2 different part numbers for with / without PDR. im not sure where the recorder actually sits - it may just be the difference of the SD card slot. if its just the SD card slot - im going to cut it. if the recorder mount area is not in my dash Ill have to change it. I dont want to change the dash - but a mans got to do what a mans got to do; right???
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
05-04-2018, 08:14 AM | #5 | |
05-04-2018, 08:42 AM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Does the instrument panel also include the SD card socket?
You'll also need the PDR-specific windshield. It appears to be 84133729. Given only HUD cars are able to have PDR, it appears logically correct.
05-04-2018, 08:46 AM | #7 |
The instrument panel does have the socket.
05-05-2018, 04:12 PM | #8 |
I went to the dealership today to get some help from the parts guy.
I cannot find any diagrams online for any of this stuff. I was able to buy the recorder bracket, recorder antenna, short recorder harness and the SD Card receptacle. Total for these was $390 from the dealer, so Im in near $1500 at this point, not including the money I spent to buy the navigation I added to the vehicle from gen5diy. Based on what I was told, the Dash harness is different on the PDR cars; the PDR wiring is integrated into the harness.
05-05-2018, 05:17 PM | #9 | |
I posted diagrams a few posts above. Part numbers to wire terminals are in there. You'd have to add wiring to the harness.
05-05-2018, 07:40 PM | #10 | |
I did look at and appreciate your help with the attachments you posted. Ive attached the recorder connector images. on one end it has a greay and black connector, which ive bought the short harness (84030546) and on the other end it has the recorder antenna and 3 micros usb ports. the camera just has one micro usb as well. based on your file, the black connector must be for the camera, and clearly the SD Card reader must plug into one of the others. maybe the extra one is left un-used but the diagram the dealer gave me shows harness number 7 using all the ports. I guess Ill know more when I pull the covers off the dash next weekend after the recorder and other parts arrive.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD Last edited by nighttowl; 05-05-2018 at 08:44 PM. |
05-06-2018, 01:06 PM | #11 |
Hello, I am looking to do the same upgrade on my Camaro, do you know if the parts list is different on the convertible? I assume most of the parts will be the same but the camera mounting might be different, I cannot seem to locate any real documentation on the parts list for the PDR outside of the above.
Here are a few items I was able to find: Vehicle Performance Data Recorder Malfunction: Display Malfunction 1. Ignition OFF, disconnect the X1 harness connector at the K161 Performance Data Recorder. 2. Test for less than 10 Ω between the ground circuit terminal 12 and ground. ⇒ If 10 Ω or greater 2.1. Ignition OFF. 2.2. Test for less than 2 Ω in the ground circuit end to end. ⇒ If 2 Ω or greater, repair the open/high resistance in the circuit. ⇒ If less than 2 Ω, repair the open/high resistance in the ground connection. ⇓ If less than 10 Ω 3. Verify that a test lamp illuminates between the B+ circuit terminal 1 and ground. ⇒ If the test lamp does not illuminate 3.1. Ignition OFF, remove the test lamp. 3.2. Test for less than 2 Ω in the B+ circuit end to end. ⇒ If 2 Ω or greater, repair the open/high resistance in the circuit. ⇓ If the test lamp illuminates 4. Ignition OFF, connect X1 harness connector at the K161 Performance Data Recorder. 5. Disconnect the X2 harness connector at the K161 Performance Data Recorder. 6. Ignition ON. 7. Test for less than 1 V between the signal circuit terminal 6 and ground. ⇒ If 1 V or greater 7.1. Ignition OFF, disconnect the X1 harness connector at the A11 Radio. Ignition ON. 7.2. Test for less than 1 V between the signal circuit and ground. ⇒ If 1 V or greater, repair the short to voltage in the circuit. ⇒ If less than 1 V, replace the A11 Radio. ⇓ If less than 1 V 8. Test for less than 2 Ω in the signal circuit end to end. ⇒ If 2 Ω or greater Repair the open/high resistance in the circuit. ⇓ If less than 2 Ω 9. Test for less than 1 V between the signal circuit terminal 12 and ground. ⇒ If 1 V or greater 9.1. Ignition OFF, disconnect the X1 harness connector at the A11 Radio. Ignition ON. 9.2. Test for less than 1 V between the signal circuit and ground. ⇒ If 1 V or greater, repair the short to voltage in the circuit. ⇒ If less than 1 V, replace the A11 Radio. ⇓ If less than 1 V 10. Test for less than 2 Ω in the signal circuit end to end. ⇒ If 2 Ω or greater Repair the open/high resistance in the circuit. ⇓ If less than 2 Ω 11. Connect X2 harness connector at the K161 Performance Data Recorder. 12. Verify the three USB cables are properly connected at all components and there is no damage to the cable or connections. ⇒ If connection problems or cable damage is noted. Perform the appropriate repair or replacement to correct any issues. ⇓ If no connection problems or cable damage is noted. 13. Ignition OFF, connect the EL-50334-50 to the P17 Info Display Module connector X5 and the performance data recorder connector X3. 14. Ignition ON, performance data recorder system ON. 15. Verify the performance data recorder system operates properly. ⇒ If performance data recorder system does not operate properly 15.1. Replace the P17 Info Display Module. 15.2. Verify the performance data recorder system operates properly. ⇒ If performance data recorder system does not operate properly Replace the K161 Performance Data Recorder. ⇓ If performance data recorder system operates properly All OK ⇓ If performance data recorder system operates properly 16. Replace the USB harness. Record Malfunction 1. Ignition OFF, disconnect the X2 harness connector at the X20 Memory Card Receptacle. 2. Test for less than 10 Ω between the ground circuit terminal 4 and ground. ⇒ If 10 Ω or greater 2.1. Ignition OFF. 2.2. Test for less than 2 Ω in the ground circuit end to end. ⇒ If 2 Ω or greater, repair the open/high resistance in the circuit. ⇒ If less than 2 Ω, repair the open/high resistance in the ground connection. ⇓ If less than 10 Ω 3. Verify that a test lamp illuminates between the B+ circuit terminal 6 and ground. ⇒ If the test lamp does not illuminate 3.1. Ignition OFF, remove the test lamp. 3.2. Test for less than 2 Ω in the B+ circuit end to end. ⇒ If 2 Ω or greater, repair the open/high resistance in the circuit. ⇓ If the test lamp illuminates 4. Connect the X2 harness connector at the X20 Memory Card Receptacle. 5. Verify the USB cable is properly connected at all components and in-line connections, and there is no damage to the cable or connections. ⇒ If connection problems or cable damage is noted. Perform the appropriate repair or replacement to correct any issues. ⇓ If no connection problems or cable damage is noted. 6. Connect the EL-50334-50 to the memory card receptacle connector X1 and the performance data recorder connector X5. 7. Ignition ON, performance data recorder system ON. 8. Verify the memory card receptacle operates properly while operating the performance data recorder system. ⇒ If memory card receptacle does not operate properly 8.1. Replace the X20 Memory Card Receptacle. 8.2. Verify the memory card receptacle operates properly while operating the performance data recorder system. ⇒ If memory card receptacle does not operate properly Replace the K161 Performance Data Recorder. ⇓ If memory card receptacle operates properly All OK ⇓ If memory card receptacle operates properly 9. Replace the USB harness. |
05-06-2018, 01:13 PM | #12 |
Attached is a few images / diagrams I was able to locate for the PDR.
The PDF Vehicle Performance Recorder Wiring Diagram might be of interest to all looking to do this. Last edited by mbnwa; 05-06-2018 at 02:59 PM. |
05-07-2018, 03:01 PM | #13 |
I'm still trying to figure out why the PDR option wasn't available for the Convertibles. I don't see anything so far that would eliminate it from the verts.
05-07-2018, 03:02 PM | #14 |
I just ordered all the parts guess we will find out shortly I know they offered it on the Vert Corvette, as I owned one in the past. Any additional info anyone finds out would be great and I will post back any of my updates after all my parts come in. I did get the PDR out of a CTS-V so fingers crossed it should be the same one it's a different part number vs what was listed above.
