03-18-2018, 04:02 PM | #1 |
Drives: 2010 2SS/RS Join Date: May 2010
Front strut bolt torque procedure??? Sounds weird to me..
It says in the manual to torque the 24mm nut to 59 ft lbs and then to turn it another 180 degrees?????????? WHY? Why not just give it one torque spec and be done with it??????
Also......watching this video they spin the nut 180 degrees but it looks like they are not holding the 24mm bolt head??? So wouldn't the bolt just spin 180? https://youtu.be/jXuoPUC7xMw Does't make sense to me.....does anyone know the correct procedure and why they do it this way????
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
03-18-2018, 06:22 PM | #2 | |
'It's an experiment'
Many bolts are TTY on our cars... TTY with angle ° are supposed to be more exact. Head bolts are that way also. One time use and in that’s case, always replace them. -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
03-18-2018, 06:28 PM | #3 | |
03-19-2018, 05:54 AM | #4 |
Drives: 2015 Z/22 Join Date: Aug 2015
If you're replacing the bolt then you can use those torque specs (59 ft/lb + 180°) but if you're reusing the bolt then typically you'll give it a grunt or two with some blue loctite as mentioned.
If you do the 59 ft/lb + 180° on a used bolt you may stretch the bolt even more and risk snapping it (bolts stretch when torqued past a certain point, and stretching them again will put them even closer to snapping). TTY bolts are used to make sure a bolt goes on as tight as it needs to; if there is rust in the threads, for example, going to 80 ft/lb or whatever may not make the bolt as tight as it needs to be, but doing 59 ft/lb then 180° makes sure it's tight, no matter the resistance.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
03-19-2018, 12:51 PM | #5 |
Thanks for the input...........very much appreciated!
03-20-2018, 09:42 AM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
03-22-2018, 10:23 PM | #7 | |
03-26-2018, 10:04 AM | #8 |
My pleasure
12-23-2022, 12:19 AM | #9 |
Is the link to more information still live Pete? Trying to get more information on changing front MRC struts-such as which nuts/bolts are needing to be replaced as they are single use.
12-25-2022, 06:41 AM | #10 |
Pretty sure Pete went out of business. I have not seen him on here in quite a while.
12-25-2022, 07:27 AM | #11 |
I'm not sure about the camaro but some strut bolts are directional as well. Make sure you put them in the same direction they came out.
