11-17-2017, 03:41 PM | #1 |
Drives: 2017 Camaro 2.0 RS Join Date: Jun 2017
Radio Rattle?
Well, my 1st issue with my 2017, minor but really maddening.
Anything other than perfect surface roads, my 8" screen rattles, I can put light pressure on it and it stops. I can play with it and its not loose but its not tight either, anyone else have this and if so how did you fix it. I thought I could put some felt behind it, but there really is no where to hide anything to quiet it down, plus I was worried about heat? Thoughts , opinions? Thanks, Chris |
11-17-2017, 06:07 PM | #2 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Can you remove the trim and make sure it’s tight? I’m not sure how it mounts. My concern would be messing something up. If you can get it to easily make the noise, a trip to see the dealer may be the best move.
11-18-2017, 11:27 AM | #3 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Mine does the same thing. I'm thinking of asking the dealership if they can fix it.
11-18-2017, 09:05 PM | #4 |
Drives: 17 SS 1LE, 02 GTP Join Date: Jan 2017
Mine just started to rattle also.
2017 Mosaic Black Metallic 1LE
11-19-2017, 07:01 PM | #5 |
It's a easy fix with 1/8th inch foam tape.
11-20-2017, 12:05 AM | #6 |
Drives: Hyper Blue 2SS Join Date: Jun 2013
mmm that sounds good. you should try that .
2SS, Hyper Blue, 8-Speed Automatic, NPP Exhaust, Magnetic Ride Control, Sunroof, Navigation, 5-Spoke Low-Gloss Black Wheels, Black Bowtie Emblems, Cargo Mat/Net
Mods: XPEL - Hood, Bumper, Headlights, & Side Mirrors JWM - Side Markers ZL1 Addons - Deluxe Rock Guards & Red Lift Pads GM - Dark Tail Lamps MRR - Gloss Black M017s |
11-20-2017, 07:04 AM | #7 |
Drives: 2017 Camaro 2SS Join Date: Dec 2016
Can someone post pictures of how they are able to fix this. I had shrugged it off, but at this point I am in the same boat as the OP. This rattle is driving me insane. Need to fix this rattle and the caps on the bottom of my doors that rattle from the door speakers.
If the foam tape works for the radio and someone can post where it needs to be installed I will be knocking them both out before taking my Camaro on it's first road trip (250 miles one way). |
11-20-2017, 10:02 PM | #8 |
Fixed mine today with some foam tape.
I removed the trim piece from the bottom and removed the two bolts holding it in. Put the tape on top between the upper hooks.
11-20-2017, 11:06 PM | #9 |
11-21-2017, 06:13 PM | #10 | |
rotohead was correct, just a little tape and it's good.
11-23-2017, 09:35 AM | #11 |
My dealership just put some thin foam tape under the head unit borders. Quite as can be now.
11-23-2017, 11:27 AM | #12 |
Drives: SS Join Date: Sep 2016
Dealership fixed mine also.
2017 HBM 1SS 1LE w/PDR
Past: 2009 Cadillac CTS-V, 6-speed manual 2008 Corvette Jet Steam Blue, manual 2005 Cadillac CTS-V, Stealth Gray 2003 Corvette Z06, Black |
11-23-2017, 11:59 AM | #13 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Smash it with a hammer. That should stop it no?
12-04-2017, 07:21 PM | #14 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
So where is everyone putting the tape? Is it as described by KS1Le where the bottom trim needs to be removed?
