09-16-2017, 10:19 AM | #1 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Uneven pad wear R vs L F wheel
It seems that Sean and I are experiencing the same symptom: RF pads are wearing evenly but much faster than LF. By about 3mm.
Any expert opinions as to possible cause(s)? I had thought my zl1addons hook might be causing it by hanging down and disturbing air flow to the cooling inlets. But Sean uses stock hook which is horizontal... Thanks in advance! |
09-16-2017, 05:53 PM | #2 |
TTT any ideas?
09-16-2017, 08:19 PM | #3 |
Drives: '18 1SS 1LE Join Date: Sep 2017
More left turns under braking?
That would put more load on the R/F brakes. Are rear pads even? If L/R is worn more than R/R I might look into the brake proportioning. Have you scaled the car, put it on a four pad scale to check your corner weights? |
09-16-2017, 08:33 PM | #4 |
Rear pads are even. I've run CW tracks so R hand turns prevail. Haven't had the car corner weighted.
Thx for your thoughts! Anyone else with the same issue? |
09-16-2017, 08:34 PM | #5 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
My vette with the Z06 caliper did it, my SS sedan with the Brembo 6 piston did it. When I put it in the air they both seem to spin the same, but never actually measured the drag. I rebuilt the Brembo' before installing them, new seals and rubbers all around along with new hoses.
Maybe something with the ABS, IDK |
09-16-2017, 08:43 PM | #6 |
Ok thx maybe it is a "feature" then?
09-17-2017, 02:05 PM | #7 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Very slight differences in the pad compound and brake rotor materials can cause uneven wear, especially on cars that see track use. I see the same thing happen on race cars, part of a normal checklist on R8 LMS and Porsche GT3 RSR's and Cup Cars is to closely examine the brakes, you'll usually find a pad or two wearing faster than the others but it's considered normal.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
09-18-2017, 07:25 AM | #8 |
Thx for the feedback. I've seen an uneven before, but never to this degree. Perhaps the weight plays a role here.
09-18-2017, 09:16 AM | #9 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
My pad wear so far has been reasonably symmetrical, nothing to write home about.
If you think you're getting asymmetrical duct flow, use Alcon temp tape strips and/or temp paint as a ballpark helper.
09-18-2017, 09:37 AM | #10 |
Good idea Ryephile - thx!
05-24-2018, 11:47 AM | #11 |
Drives: 2017 SS 1LE Hyper Blue Join Date: Jun 2017
Uneven pad wear top bs bottom
Hey guys, yesterday I was surprised by an extremely uneven pad wear of the bottom of my front pads (see images). On both left and right the same! Any ideas what this could be caused by??
I always inspect pads after each session but only look from up... there I had still some material left. Now on the lower end, the pads were completely gone after the last session and I only noticed by chance due to scratching. I haven’t heard that the pad could wear unevenly in itself, only left and right like discussed here. My mechanics say that they have for sure not damaged the calipers when replacing the pads last time. |
05-24-2018, 12:09 PM | #12 |
Hot Dog
What pads? Are those accurate looking pictures of the transfer layer? It looks horrible, like you just washed the car and the rotors rusted and then you rolled it a hundred feet and stopped.
05-24-2018, 12:44 PM | #13 | |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
2018 1SS 1LE
05-24-2018, 01:13 PM | #14 | |
The weather yesterday and the previous track day was rather warm, around 74 and sunny. I was thinking if it could be uneven pressure of the calipers due to temps.. and if anyone switched to steel flex. I haven’t heard of that being an issue though :/ Fluid is Motul 660. Did a 50% flush when changing pads. Will call the break shop tomorrow, they have good racing experience. At this point I’m completely clueless, any suggestions appreciated. Also: does anyone know whether the original rotors (part number 23142500 And 23189768) are made by AC Delco? Found a good page that delivers to Germany but they don’t use gm part numbers. Fits the ATS-V so looked good. My previously ordered OEM rotors by gmpartsdirect won’t make it here in time. ... Regarding the layer: Here are some disc pictures from winter before changing (when my OEM pads were done. Those lasted 5 days) |
