TireRack
Old 09-03-2017, 08:08 AM   #1
Chris93Si
Drives: 2015 Z28
5mm wheel spacer, where to buy?
Just as the title says, looking for a 5mm wheel spacer for my Z to accommodate 325/30-19 Trofoes and can't seem to find what I need. I'd rather stay away from the eBay specials and look for a higher quality piece. ZL1addons has a 5mm on their site but don't seem to have them in stock. Can anyone point me in the right direction? Thanks in advance
Chris93Si is offline   Reply With Quote
Old 09-03-2017, 09:08 AM   #2
iownedu
Drives: 2014 Camaro Z/28
eBay may be your only option for a 5x120 66.9 5mm spacer.
H&R makes some but they are a 70mm hub. You probably won't find any with a hubcentric ring into your wheel being that thin.
2014 Camaro Z/28. Last Pre-Production car, #69. White without A/C, 1 of 4.
2008 Mercedes AMG C63
Longtubes, Intakes, Wheels, Coilovers, Tune
2006 Lamborghini Gallardo SE
Gated Verde Ithaca
Heffner 1000TTG
iownedu is offline   Reply With Quote
Old 09-03-2017, 12:50 PM   #3
camguynj
camguynj's Avatar
This is where you want to get your spacers from ...custom cut hub centric with/without lip from billet aluminum.
http://www.motorsport-tech.com/wheel_spacers.html
Old 09-05-2017, 06:09 AM   #4
Chris93Si
Drives: 2015 Z28
Thanks for the info guys, placed an order with Motorsport Tech
Old 09-05-2017, 11:38 AM   #5
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Are you keeping in mind that the Camaro is Hub-Centric not Lug-Centric?
The raised collar on the hub is 66.9 mm and designed to engage directly in to the wheel center bore. The studs do not carry the full vertical vehicle load. I do have a spacer/adapter for my spare that also has a raised collar and retains Hub-Centric interface with the wheel, is that what OP ordered? If that interface is missing it loses some of the strength and also can cause vibration. Thinking this applies to both Z28 and SS.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 09-05-2017, 11:46 AM   #6
D2M
D2M's Avatar
Drives: Z/28
At 5mm spacer you will most likely not engage the center hub as it only sticks out about 9/10mm if I remember correctly. You may get e shimmy / vibration. You can get away with a 3mm spacer for sure however.
D2M is offline   Reply With Quote
Old 09-05-2017, 11:50 AM   #7
pat_t
Drives: .
I can confirm that 5mm is thin enough that the hub-centric interface with the wheel is retained (the hub protrusion is about 12-13mm).
If you went any thicker you would need a hub-centric spacer with a collar though.
Also for accuracy the hub centres the wheel preventing out of balance and vibration. The vertical load is actually mostly carried by the clamping force between the wheel face and the hub face though, created by correctly torqueing the wheel nuts.
Edit to say - I'm running 5mm spacers all around, and don't have any vibration at upto 130mph...
pat_t is offline   Reply With Quote
Old 11-16-2020, 08:01 PM   #8
Genfive427camaro
Drives: 2015 Z28
Do you by chance remember how much they were?
Genfive427camaro is offline   Reply With Quote
Old 11-17-2020, 09:06 AM   #9
camguynj
camguynj's Avatar
Just to add further info on stud length clamping/torque requirement...
5th Gen factory stud length is 28mm. Lug size is 14mm diameter x 1.50 pitch.
The calculation for required lug length torque is (Diameter x Pitch) so on 5th gen cars it’s (14mm x1.5) = 21mm
I have 3mm spacers so 28mm-3mm= 25mm of stud length. I was able to get around 9 turns of the lug. 100% of the torque is achieved at the 6 turn, the extra turns don't add anymore tighting/torquing. With 5mm spacers you have 23mm stud length which is 2mm more than what’s required for max torque clamping.
Old 11-17-2020, 05:17 PM   #10
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
I run the ZL1 add-ons 5mm spacer up front with a set of Detroit Speed Engineering open ended lug nuts. I get 8 full turns on the nuts, no issues with vibration or handling, running a 305 30R19 street tire (Trofeo or Goodyear Eagle F1 Supercar 3R) or a Hankook F200 Ventus 300/680R19 slick with -3.1 camber, zero toe.
AustexaSS is offline   Reply With Quote
