Old 08-17-2017, 11:06 AM   #1
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
PDR Microphone
Anyone know how to remove the cover that houses the PDR camera and microphone? I'm trying to remove the cover and get to the microphone to test out some wind buffering covers. Not sure what directions the clips are and I don't want to break it.
2017 SS 1LE (sold)
Nightfall Gray
Th3Beast is offline   Reply With Quote
Old 08-17-2017, 11:26 AM   #2
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I have no clue, but I would try the same if you figure out the mic location.
mjk3888 is offline   Reply With Quote
Old 08-17-2017, 11:35 AM   #3
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
The microphone is definitely through this small hole. I started a recording and tapped the bluetooth mic location and this one. Could barely hear the tapping on the a-pillar.
2017 SS 1LE (sold)
Nightfall Gray
Old 08-17-2017, 11:36 AM   #4
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
I thought it used the same mic as the Bluetooth, in the a pillar?
RXtacy is offline   Reply With Quote
Old 08-17-2017, 11:38 AM   #5
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
So did I, but reading around said that is uses a dedicated mic. It's in housing in the above picture.
2017 SS 1LE (sold)
Nightfall Gray
Old 08-17-2017, 11:42 AM   #6
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
NICE! I literally might tape a cotton ball over it and see if it helps with wind noise at my track day on the Charlotte Roval on 8/29!
I got an idea! I might take the foam I pulled out of the intake sound tube and use it as a wind buffer here.
Old 08-17-2017, 11:44 AM   #7
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I can confirm that, because I use my PDR as a dash cam on daily commutes and I can take bluetooth calls without my PDR audio dropping out on the recordings.
Old 08-17-2017, 12:35 PM   #8
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
I like it. Should only need a tiny piece. I'll give that a shot today and see if it works. I'd really like to get to the microphone itself to be able to cover it completely if possible.
2017 SS 1LE (sold)
Nightfall Gray
Old 08-21-2017, 07:34 AM   #9
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Yeah I would like to see some information on how to access the mic inside the casing as well.
Old 08-21-2017, 07:51 AM   #10
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
I stuffed a tiny bit a foam in that mic hole and seemed to help ever so slightly. Still a lot of wind noise above 100. Really need to get to the mic itself and see if that works.
2017 SS 1LE (sold)
Nightfall Gray
Old 08-21-2017, 09:22 AM   #11
Mr. Meh
Drives: Sold
It's also possible that the mic hole isn't a sealed connection directly to the pickup and that the entire front area where the camera is located is opened enough to affect it. Might also need to put foam (a ring) around the lens and behind it to stop buffeting there as well from reaching the area adjacent to the pick up.
Mr. Meh is offline   Reply With Quote
Old 08-21-2017, 09:31 AM   #12
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
I think that is probably the case too. Getting to the mic directly should take care of that. I have a track day this Saturday and I'm too chicken to mess with the cover any further in fear of breaking the clips. Then I'd be really SOL lol.
2017 SS 1LE (sold)
Nightfall Gray
Old 05-16-2018, 07:53 AM   #13
bluegixxer007
Drives: Audi A4 3.2L
Did anyone make more progress with the buffeting problem?
Did anyone get any further with the PDR buffeting problem? This post caught my attention cause I get a ton of buffeting at the track (Watkins Glen & Road America), like others noted above 100 MPH especially. I was hoping to see if someone was successful in their attempts to deal with this before my next track day in 2 weeks. Thanks!
bluegixxer007 is offline   Reply With Quote
Old 05-16-2018, 08:14 AM   #14
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
I've come up with the only solution I could figure out. I took down the camera unit, disassembled it, and made new connections to extend the microphone out to inside the trunk.
The larger problem is the sound processing ability on the camera board is just piss poor. Nothing close to the quality of GoPro.
I tested many locations for microphones inside the car, all of which still had sound cutting issues. My final install is I neatly concealed the cord with long extension all the way into the trunk.
I ended up using this microphone, http://a.co/ccXdI0F (even though the car is mono), as all the lapel mics I tried still had cutting issues. Check out my PDR video below to see how well it works compared to factory.
2017 SS 1LE (sold)
Nightfall Gray
