Vararam
Old 08-08-2017, 10:26 AM   #1
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
License Plate Bulb Housings Won't Hold Bulbs
Discovered one bulb out above my license plate, so I bought new LED bulbs to just go ahead and replace them both with.
Took one housing out and discovered no bulb, wire, nothing.
I believe it fell out down in the bumper and I can't reach it.
The housings look broke or maybe got hot and don't hold the bulbs anymore.
Anyone else have this issue?
Left side
Right side no bulb or harness
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 08-08-2017, 11:30 AM   #2
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
I think I remember something about these lamps burning the plastic facia way back when the 5th gen was
new. Not positive though, but it may have been a warranty issue. I bet someone else here will remember.
myold88 is offline   Reply With Quote
Old 08-08-2017, 02:05 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I think there is a TSB on this exact thing.
InFiD3ViL is online now   Reply With Quote
Old 08-08-2017, 02:09 PM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
It was never a recall so notices were never mailed out. It was a TSB, I believe.
Only those Camaros affected will be serviced for the issue. If you bring your car to the dealer with the issue they will install updated housings.
This should apply even if your warranty has expired.
BTW, if you remove your license plate there are two large openings where you will probably locate the missing socket.
2011 1SS/RS LS3 CGM
Old 08-08-2017, 04:09 PM   #5
John_C
LSx FTW!!!
John_C's Avatar
Cool.
I'll swing by a dealer and see if they can fix it.
Thanks, guys!
HP Tuners VCM Suite
Old 08-08-2017, 06:15 PM   #6
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Originally Posted by John_C View Post
Cool.
Thanks, guys!
If they give you a hard time, show them this.
http://gm.oemdtc.com/4785/rear-fasci...evrolet-camaro
Old 08-08-2017, 08:19 PM   #7
RandRSS
RandRSS's Avatar
Drives: 2010 SS Camaro Eforce SC
WOW! Wish I had seen that before, I think I paid $57. For a harness and the 2 housings with lenses. Guess that doesn't sound so expensive, but free would have been really nice!
RandRSS is offline   Reply With Quote
Old 08-08-2017, 11:43 PM   #8
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
If you paid for replacement parts you can show GM your invoice and get reimbursed...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 08-09-2017, 07:09 AM   #9
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
Thanks of the info , my 2011 has never been to a dealership.
I think I'll get this done.
amz is offline   Reply With Quote
Old 08-09-2017, 10:41 AM   #10
John_C
LSx FTW!!!
John_C's Avatar
Thanks! I'll print that off!
HP Tuners VCM Suite
Old 08-09-2017, 11:20 AM   #11
John_C
LSx FTW!!!
John_C's Avatar
Found my bulb....
Melted in to some wire harness loom. :(
HP Tuners VCM Suite
Old 08-09-2017, 01:28 PM   #12
lafountain
lafountain's Avatar
Drives: 2011 Synergy Green 2SS/RS
Have only had my car since May, now I have something I need to check when I get home.
Hey, you want to lay the fate of the world on the kid's Camaro? That's cool.
I bought a car, turned out to be an alien robot. Who knew?
lafountain is offline   Reply With Quote
Old 08-10-2017, 06:56 AM   #13
John_C
LSx FTW!!!
John_C's Avatar
Find anything?
HP Tuners VCM Suite
Old 08-10-2017, 04:56 PM   #14
nosmr2
Drives: 2011 L99 SS
Mine melted on my 2011 in 2015, emailed GM, then got a call back, took about 30 minutes on the phone with India, I sent them my receipt, they sent me a check back.
2011 SS
ADM LSA Conversion
nosmr2 is offline   Reply With Quote
