TireRack
Old 04-30-2017, 05:26 PM   #1
14ssrs6man
14ssrs6man's Avatar
Drives: Summit White 2014 2SS/RS 6spd
Installing Powder Coated Calipers 14' SS
Hello,
getting some powder coated calipers, My car has 9k miles. I am either going to re-use my OEM rotors and pads or buy slotted/drilled w/new pads (I don't track my car). I am also upgrading to SS brake lines. If I use existing rotors/pads, what if anything do I need to do to them before re-assembly and after?
Thanks!
Dan
Your car must be very fast! You were haulin' ass when I passed you!
14ssrs6man is offline   Reply With Quote
Old 04-30-2017, 06:06 PM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Just clean everything up with brake parts cleaner, and reassemble it. New calipers should work just fine with your existing used rotors and pads, provided they are in good working order. I have new slotted R1 Concepts rotors to install, and may use my old pads if they have sufficient material left.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 04-30-2017, 06:16 PM   #3
14ssrs6man
14ssrs6man's Avatar
Thank You!
Dan
Old 04-30-2017, 11:04 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
As long at your rotors are not grooved, have a seriously lip at the top or bottom, or warped there is no need to do more that what Oldudesrule mentioned. Scuff with some fine grit sandpaper (rotors and pads), clean, and grease! As for the SS lines. Having a rubber mallet helps when bleeding. Light taps on the caliper help air bubbles rise to the top and thus out the bleeders. If memory serves correctly it is INNER then OUTER bleeder. Farthest caliper to closet to the master cylinder.
More to come.
Black_SS10 is offline   Reply With Quote
Old 05-01-2017, 05:46 AM   #5
14ssrs6man
14ssrs6man's Avatar
Thank You! So if I do the sanding/greasing, I will have to re bed the pads correct?
Dan
Old 05-01-2017, 09:35 AM   #6
Black_SS10
SomeguyK
Black_SS10's Avatar
Yes. Re bed the pads.
More to come.
Old 05-01-2017, 10:46 AM   #7
14ssrs6man
14ssrs6man's Avatar
Thank You!
Dan
