04-03-2017, 11:51 AM | #1 | |
Drives: 2017 A10 ZL1 Join Date: Mar 2017
Vengeance Racing A10 ZL1 hits the drag strip
This past Saturday we made it to Carolina Dragway for some testing prior to starting the modification process on our A10 ZL1. I drove the car a bit over three hours from our location to the drag strip and literally pulled it right into the staging lanes. The result was 11.41@124.61 on street tires. I pulled back around and bolted up a set of drag radials mounted to a set of Weld wheels. I had a set of front runners as well, but the calipers on the ZL1 would not clear them so we bolted up the stock front tires and went back out to make two more hits. You can see from the time stamp on the slips there was no cool down between runs. Our focus was on getting an accurate baseline prior to modifying the car. Bolting on the drag radials picked up a solid tenth, but could have gone faster with some tuning. You can literally feel the torque management pulling the power down on the launch. I am 100% confident that with a proper ECU calibration and a drag radial that 10s are doable.
Here is a video of one of the runs. I apologize for the delay after the burn out. I was setting up EFI Live to log the run. The car leaves today to head to ProCharger for design/fitment of an aftermarket supercharger system. Initial fitment will include their D1SC head unit and an air to air intercooler. Once that is complete they are going to install an F1A-94 with an air to water intercooler. The car will then be returned to us for installation of our complete heads/cam package/fuel system upgrades/Kooks Header system and ECU calibration. I will keep everyone updated as we make progress. We understand everyone may not take their ZL1 to this extreme, but we have years of experience with the LT4 and know what kind of power it can support. Our goal is to push this A10 transmission to find its limits so that we are able to offer reliable performance packages to our customers. |
04-03-2017, 11:57 AM | #2 |
Built and Tuned By Hhp
Drives: . Join Date: Mar 2017
Good stuff I love it! Do you mind giving me the specs of your drag radials and weld wheels. Looking to get a set.
04-03-2017, 12:10 PM | #3 |
04-03-2017, 12:10 PM | #4 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Nice!
04-03-2017, 12:14 PM | #5 |
Great stuff Ron!
You come out from idle, or stall it up some? |
04-03-2017, 12:16 PM | #6 |
Thanks Ron, I truly will take your word over others.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
04-03-2017, 12:19 PM | #7 |
Drives: Fast Join Date: Mar 2015
Best shop in NA! Great stuff, keep it up.
04-03-2017, 12:29 PM | #8 |
04-03-2017, 01:03 PM | #9 |
Drives: 2017 Summit White ZL1, M6 Join Date: Jan 2017
Hey Ron, absolutely great runs! I'm curious as to what modes you had it in as far as LC goes etc? I'm new to this car and all the electronic stuff but not racing, just trying to learn is all. Thanks!
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396 |
04-03-2017, 01:08 PM | #10 | |
I had my best luck with traction/stabilitrak disabled and the car in "Track" mode.... I tried numerous other configurations, but this one seemed to work best. The "Launch Control" feature itself was horrible. This might be more useful on the street or non prepped surface, but at the track it slowed the car down and cost quite a bit in the 60ft. I tried 5%-15% slip and up to 2400rpm with no success. |
04-03-2017, 01:24 PM | #11 |
Drives: 87 GN, 05 GTO Join Date: Aug 2011
Good runs! I'm surprised at the lack of gaining 25-27 mph like I would expect from a car at this power level with the close ratio trans gearing. Was there any logging? I wonder about detonation. Surprisingly the V3 I watched on the dyno was detonating pretty consistently in the upper rpms.
1987 Buick Grand National 10.70@128
2005 MBM 6 spd GTO 7.00@ 103.7 mph 1/8th |
04-03-2017, 01:31 PM | #12 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
It was only a matter of time before the best in the business got the shop ZL1 on the track
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
04-03-2017, 01:46 PM | #13 |
04-03-2017, 02:11 PM | #14 |
Drives: 1993 z28 Join Date: Nov 2015
can view slip
