TireRack
Old 03-26-2017, 04:04 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
ACT twin disk.
Who has them and how are you liking them?
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 04-07-2017, 04:23 AM   #2
2010_camaro
Am I the only one? Lol
Old 04-07-2017, 07:31 PM   #3
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Had it for about 35k miles and hated it. Swapped it out with an RXT and will never use an ACT again.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 04-08-2017, 03:08 PM   #4
2010_camaro
What was bad about it?
Old 04-08-2017, 03:22 PM   #5
flyinglow57
Drives: rumble bee,2SS 6sp
I have one and hate it also. Cam only and it slips. When I do full throttle 1-2-3. And my clutch pedal will stick to the ground. I would have sold my car already but I. Feel horrible to put it for sale with this shiitty of a clutch in it
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 04-09-2017, 04:22 AM   #6
2010_camaro
1550ftlb clutch slipping on cam only? Clutch sticking to the floor? Sounds like you have the dreaded throw out bearing support failure.
I figured people would hate the chatter or the on off switch feel.
Old 04-14-2017, 01:36 AM   #7
2010SSRSM6
2010SSRSM6's Avatar
Pedal was stiff, wandering engagement and at 600rwhp it slipped badly.
Old 04-14-2017, 05:10 AM   #8
Mise
Drives: 2014 soon to be Copo
The Mcloed twin disc is the way to go imo
Mise is offline   Reply With Quote
Old 04-14-2017, 11:31 AM   #9
Bo White
Bo White's Avatar
Buddy of mine has one and its consistent on the pedal and doesnt slip. It does however doesnt like to be slipped at the track so if the track doesnt hold the car from a clutch dump its going to take more finesse than usual to get it off the line consistently.
Old 04-14-2017, 01:19 PM   #10
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
McLeod or monster twin or street slayer / rps
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-19-2017, 09:24 PM   #11
flyinglow57
I replaced the throw out bearing and I hate the chatter and the on off. My wife won't drive the car anymore
Old 04-20-2017, 09:37 AM   #12
2010SSRSM6
2010SSRSM6's Avatar
I replaced the slave, master, TO bearing and sleeve around the TO bearing and it was still a pile o'crap. My wife wouldn't drive the car after it went in either.....
Luckily it didn't last very long and the RXT fixed all my issues. When this one is dead I'm likely going TH400 or 4L80E with a manual valve body.
Old 08-06-2017, 10:35 AM   #13
stevieturbo
Drives: it changes
Exactly which one, they make a few ?
I used their T2S-G01 on my old LS/T56. Can only say good things about it. It did eventually slip, but it did hang on for much longer than I ever expected, and it was only rated for around 875lbft. Think I used it for about 4 years or so before changing last year
Car always drove perfectly smooth.
I replaced it with another brand...and by **** I wish I'd just bought another ACT with a higher rating. Current clutch has been a ****ing nightmare !!
stevieturbo is offline   Reply With Quote
