01-14-2017, 06:17 PM | #1 |
Drives: 2017 zl1 Join Date: Dec 2016
2017 zl1 reving up by itself
last week I was leaving work and was kinda pulling forward slowly working the clutch and giving the car a little throttle and then all of the sudden I had the clutch engage and my foot off the throttle and the car revved up to around 4k rpm by itself ,then yesterday it did the same thing after I picked up my son from school same thing I was working the clutch and pulling forward because of traffic and it did it again and then today did the same thing ,I checked the accelerator pedal its all good there is nothing pushing it or in the way what could be causing this the car only has 1,800 miles?
01-14-2017, 09:25 PM | #2 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
Probably a bad TPS. If it is doing it enough then take it in and the dealer should be able to fix it.
01-15-2017, 09:35 AM | #3 |
thanks I will
01-15-2017, 09:55 AM | #4 |
Lashu74
Drives: 2017 ZL1 Join Date: Dec 2014
I would think that a bad tps would throw a cel. Do you notice it with rev matching on and off? Definitely take it to dealer asap hopefully they can replicate it, you should try to record it if possible so you have proof. Bummer man hope they get it taken care of for you!
01-15-2017, 09:56 AM | #5 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Could you have had rev matching enabled?
01-15-2017, 11:34 AM | #6 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
+1 This would be my guess....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
01-15-2017, 11:40 AM | #7 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Was the motor warm, or did you jump in and go? My car will accelerate on its own pretty hard if I just hop in and go. I made a topic about it on my SS when I first got the car.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
01-15-2017, 11:51 AM | #8 |
Drives: 2017 ZL1 10 Speed Hyper Blue Join Date: Jul 2016
2017 ZL1
01-15-2017, 04:05 PM | #9 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Why would rev match cause it to rev up when trying to pull out? Isn't it supposed to match engine revs with the speed of the vehicle (which would be near zero for his instance), the gear you're in, and the gear you're shifting to? The only time it should rev the engine is when downshifting to a lower gear and it should rev it to the RPM that the new gear would need for the current speed. Not saying it's not a possible cause. Just don't understand why it would be.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
01-15-2017, 04:21 PM | #10 |
Lashu74
Agreed, I was asking because if it was only doing it when it was on maybe the rev matching was malfunctioning?
01-15-2017, 04:22 PM | #11 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
My guess is active rev match causing the problem. But, ARM is off by default at start up from what I read.
01-15-2017, 07:06 PM | #12 |
Correct. It is off by default and must be turned on.
01-16-2017, 12:41 PM | #13 |
Drives: 2017 ZL1 Nightfall Gray Join Date: May 2013
Wow, I thought I was crazy when it happened to me... Wow.
I actually had this happen to me at the greatest time a few weeks ago. I had just grabbed my food from the window at a Chik-fil-A drive through, and I pulled forward slightly and then depressed the clutch to slow down stop again... The damn thing revved steadily to 4k-5k or more. I pulled it out of gear and released the clutch and a few other things in that split second it couple seconds. Not sure what finally made it normalize because it was honestly VERY damn stressful. It was a crowded lunch time and they had the employee out directing the loop around the building... So yeah, it was quite the spectacle surrounded by other cars, folks walking around and a handful of employees out there too. Pretty damn embarrassing actually. It happened that once and hasn't happened since, but I hope it doesn't happen again. Seems like a pretty dangerous thing that the car has the potential to revv like that... Imagine the horrors depending on the scenario... a lot of potential for someone to get hurt, the car to get hurt... Damn. I would love to know what the issue is here, and I'm certain that this cannot be replicated in front of the dealer's service department...
Now Driving:
2017 Camaro ZL1 A10 | Black 2016 Stingray Z51 A8 | Corvette Racing Yellow Past Rides: 2017 Camaro ZL1 M6 | Nightfall Gray 2013 Camaro ZL1 M6 #6052| Summit White |
01-16-2017, 01:07 PM | #14 | |
