12-12-2016, 11:52 AM | #1 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Nitto NT555 Tires + Track = no good.
So I picked as set of NT555 for around $500. No bad I thought.
They did ok at Chuckwalla a few weeks ago. Just got back from Big Willow rack track....I dont think they held up well. I was pushing hard the last few laps in the third session. Brakes were smoking coming into the pits. Buddy said he saw my rotors glowing. lol So what do you guys think? Bad tire or just to much car for these type of tires? This was on the front left tire. Maybe the big sweepers in turns 2 & 9 killed this tire?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
12-12-2016, 12:36 PM | #2 |
Drives: 62 Chevy & 2021 1SS/1LE manual Join Date: Aug 2010
at first glance, it looks like it was rubbing on something. the line is straight all the way around. in the close up though, it got real hooott. id still make sure on the rub just to put that out of my head. ive seen NT01s come apart when pushed hard. 888s blister and get out of round after about 4 track days. Nitto replaced an NT01 for a guy that came apart on the first track day he ran it.
does the left rear look like this at all? did the other tires get this melted look? how much negitive camber are you running up front? |
12-12-2016, 01:30 PM | #3 | |
KaBoom1701
Alignment specs: Front 2.1 neg camber Rear 1.5 neg camber
Mods:
12-12-2016, 08:34 PM | #4 |
Apex Predator
Drives: 2010 2SS/RS M6 Rally Yellow Join Date: Jul 2013
On J-Rod's point, just about any tire will do that if overdriven. I smeared and chunked my PO-purchased Nexen N3000's all over the track. NT555 makes for a good daily tire, but you certainly can take steps to make them live in this environment. Smooth inputs and knowing when to back off will go a long way.
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991. |
12-13-2016, 12:06 AM | #5 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
These are my 888s after 7 track days... two of those days were 2 sessions of skid pad and braking/handling excercises... I was able to get tire temps from a vendor at the track a few times inwas there... showed almost even temp across the inner middle outter portions of the tire. Alignment was spot on and i was not over driving the car. |
12-13-2016, 05:45 AM | #6 |
the tire appears to have overheated or been overdriven. Get a more appropriate compound for the track, recheck alignment and tire pressures. Possibly, adjust your driving technique. Remember "Days of Thunder": his way vs my way...
12-13-2016, 06:46 AM | #7 |
corner barstool sitter
285/30-20 seems a little undersize for a 4000+ lb car being driven enthusiastically, and the OE wheel being only 10" wide isn't helping. Possibly underinflated as well.
Did you run up a few hundred easy to moderate pace street miles on them before hitting the track? Norm
12-13-2016, 09:51 AM | #8 | ||
KaBoom1701
Ben thinking of 295/35R20 up front and 315/35R20 in the rear on the next go around.... Any tire suggests are welcome from my fellow aggressive track peeps.
Mods:
12-13-2016, 02:19 PM | #9 |
op, slap a square set of 305s in that new RE71. thats what a lot of those optima cars were running last year. they can afford anything, but they have to stay at or over 200 treadwear. they will wear some though. the MPSS will wear good and give decent grip. |
12-13-2016, 09:10 PM | #10 | |
12-13-2016, 09:57 PM | #11 | |
KaBoom1701
I agree with you as I ran my GY G2's the same as what you stated.
Mods:
12-14-2016, 12:23 PM | #12 | |
Drives: Race Car Join Date: Sep 2009
I would be looking for a different tire |
12-14-2016, 10:01 PM | #13 |
What about track abrasivness compared to your last track outing??
Orange Krush II
12-14-2016, 10:12 PM | #14 | |
KaBoom1701
Big Willow seemed a little on the rough side to me. Even on the straights it was bumpy.....you had always be on alert with both hands on the wheel on this track.
Mods:
