08-26-2016, 09:34 PM | #1 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2011
Comp cam trunnion after 15k miles
I'm currently replacing my comp cam trunion upgrade since I was replacing my valve springs and found them like this. I've seen people say it might be installer error and some just blame the design. Most are like this of not worse. Guess I'll see how the smith bros kit does after a few thousand miles and hope there's no catastrophe
08-26-2016, 09:39 PM | #2 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Been there, they are junk. The bushings will be a better alternative for sure.
08-26-2016, 09:52 PM | #3 | |
Drives: Camaro Justice Join Date: Jun 2007
08-26-2016, 10:04 PM | #4 |
Was the Jannetty rough idle blower with comp cams springs .675. Changed both out already
08-26-2016, 10:28 PM | #5 |
I've got almost 110K on my stock rockers.
BTR cam and springs
08-27-2016, 07:35 AM | #6 |
Drives: '10 Camaro 2SS Join Date: Jul 2013
I'd be curious to see if the BTR trunion kit wears out just as quickly. I don't think the needles falling out would be an issue on the BTR Kit because the snap rings are way oversized compared to comps.
08-27-2016, 08:14 AM | #7 |
Drives: camaro ss\rs Join Date: Jun 2014
oh god! i'm going to buy the bushing kit as soon as i'll be in new york
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
08-27-2016, 08:33 AM | #8 |
Drives: 2006 Z06 Join Date: Oct 2010
Same thing in my car. Comp uses soft metal that wears. Anyone that has them should swap asap.
Nick
Corvette Z06 -1200ish rwhp |
08-27-2016, 08:56 AM | #9 |
Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
I JUSt bought a BTR stage II package with a truninion kit from Comp (BTR was out of stock of their own). Should I not install it? I'm concerned now and wonder if I should leave it stock. Thought the "upgraded" truninion would be a good thing?
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast |
08-27-2016, 09:58 AM | #10 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Now I'm wondering if I made bad decision installing mine. Don't feel like pulling it apart again
08-27-2016, 10:11 AM | #11 |
Drives: 03 vette, 94 trans am, 04 gto Join Date: Jul 2012
yup comp trunions = poop
08-27-2016, 11:12 AM | #12 |
old school chevy rodder
Crap I am running them and hope they live 25k that load wear on the trunnions looks bad waiting to fail Hope my oil makes a difference along with the volume..... >675 springs though must be more lift on that rough idle blower cam than I thought?
http://**************************-ca...st-here-4.html http://**************************-ca...st-here-4.html http://**************************-ca...st-here-4.html **************************-camaro-power-adder-tech/ dang thing wont post says ...**************************-camaro-power-adder-tech/1705862-jannetty-racing-review-issues-problems-please-post-here-4.html[/url was just a quick search for jannetty rough idle blower cam specs leading to whole can of ugly worms.... damn it keeps deleting the ls1tech.com/forums.gen 5 Camaro power adder stuff like wtf ..... LOL
08-27-2016, 01:48 PM | #13 |
Drives: 13' 1LE Join Date: Apr 2012
Stock rockers on last LS1 outlived 3 engines, all cammed, 120k mileage. yo
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
08-27-2016, 02:54 PM | #14 |
This is the BTR Trunion after 25,000 miles. Im currently on the Straub bushings.
IMO the trunion is not hard enough for a needle bearing. Mine were Rockwell 45 C scale. Also this was with a single beehive 130 / 370. The worst trunion had a .003 depression in the problem area. Ill report back once I have a lot of miles on the bronze bushings.
