07-09-2016, 09:11 AM | #1 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Manuals who have raced/done high rpm shifts, any issues with grinding or pedal stick?
As the title says. Lots of 5th gen SS owners had issues with high rpm 1-2 grinds or the clutch pedal sticking to the floor after high rpm shifts. There were some ways to fix this, but I'd of course rather not have to...
Any 6th gen SS owners have similar issues? I know a few updates have been done, and plenty of owners have ripped off countless high rpm shifts and hit the drag strip as well. I can't recall reading about any similar issues yet, but figured a thread would be a good place to talk about this. So, those of you who fit the bill, input? Last edited by SS 1LE; 07-09-2016 at 11:47 PM. |
07-09-2016, 09:28 AM | #2 |
I was lucky with my 5th gen and only had one stuck pedal incident in 32K miles. So far with 2500 miles on the 6th gen - no problems. While I don't make a daily habit of high rpm "shits" (got to love spell check and auto correct huh!) or hard launches - I have done enough to feel this car is good to go.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
07-09-2016, 10:23 AM | #3 |
The Doctor is in
Drives: 2016 Camaro 2SS Nightfall MRC NPP Join Date: Jan 2016
I have had 0 issues with this. 3700 miles, 35 autocross runs. We shall see what happens over the next few years. I feel completely in sync with the transmission and clutch with no unpredictable behavior lately.
07-09-2016, 10:30 AM | #4 | |
Drives: 2016 2SS Join Date: Mar 2014
Only issue with going first to second is at the track where I get to much spin. |
07-09-2016, 11:48 PM | #5 |
マスタング = 遅い
Sounds good so far...anyone else?
07-10-2016, 12:40 AM | #6 |
In my experience if you pull the shifter a little early at red line that can happen but I'm yet to experience that.
07-11-2016, 04:28 PM | #7 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
no problems here so far with the transmission. just hit 5000 miles and do quite a bit of "spirited" runs now and then, and never have I run into this problem you speak of.
07-12-2016, 03:17 PM | #8 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I come from living with an MT82 for the past years. Soo glad to be shifting a Tremec.
Mine has been 100% golden. I know the GT500's had a lot of 1-2 block-outs and grinding with their 6060's. That was 1. due to a dynamic reduction in clutch disengagement at high RPM, 2. driveline windup (solid rear axle) and 3. a short throw shifter. There were synchro improvements that effected Camaro and Challenger as well. |
07-13-2016, 08:57 AM | #9 | |
マスタング = 遅い
Glad the TR-6060 in the 6th gen seems to be problem free in regards to these two issues though. |
07-25-2016, 09:42 PM | #10 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
Zero issues, even going 12.04, and driving the snot out of it.
07-27-2016, 12:33 PM | #11 |
Yes, a problem mostly solved in the 5th gens by adding a seperate clutch reservoir and changing the fluid in the reservoir often. My 1LE with 625 RWHP and a stock clutch and a separate reservoir ran I don't know how many runs and no problems with the clutch except taking it down to the rivets. Before that even at stock power, those problems you said, clutch slipping, pedal stuck to the floor, grinding.
My M6 CA6 SS has over 100 runs at Atco and 0 problems so far. The fluid still looks good. No need for the reservoir I think. Still if you race the car regular fluid service is a good idea.
"Democracy Dies in Darkness" |
07-27-2016, 12:34 PM | #12 |
Yes you are!
07-27-2016, 12:38 PM | #13 | |
Daily Driver 24/7 365
Drives: '15 CRT 2SS/RS/1LE Join Date: Jul 2015
"notchy" feeling and 'grinding' feel on the other hand - LOTS of 5th gen manual SS owners have reported this - even after fluid changes. seems to be a characteristic of the transmission.
NPP Fuse Pull, Z28 CAI =
Previous Rides: 2005 Magnum R/T A5 CAI, Cat-Back 2014 RRM Camaro 1LT/RS A6/NPP CAI Follow Me On Instagram! |
07-27-2016, 12:49 PM | #14 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I've only gone bananas with it a couple of times, but no issues.
Ordered 3/8/16- NFG/Ceramic White, M6, MRC, NPP, 6 pots, blk blade, no sunroof, blk splitter, blk bow ties, dark tails, nav.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
