06-24-2016, 09:08 AM | #1 |
RPI Designs 2016 Camaro SS Borla X-Pipe with Mid Pipes 60606 Cat Delete
2016-2018 Camaro SS Borla X-Pipe with Mid Pipes 60606 Cat Delete
2016 Camaro SS 6.2L V8, Automatic/ Manual Trans Rear Wheel Drive 2 door. This X-pipe assembly bolts on behind the primary cats and eliminates the secondary cats. It does not include AFM valves. X-Pipe without AFM (secondary cat-delete; competition/racing use only); This X-pipe assembly bolts on behind the primary cats and eliminates the secondary cats. It does not include AFM valves Item # 60606 Website Link : http://www.rpidesigns.com/shop/item....06-cat-delete/ Last edited by RPIDon; 12-17-2017 at 05:43 PM. |
06-24-2016, 10:09 AM | #2 |
Drives: 6GC Join Date: Apr 2016
Does this X-pipe bolt up to the factory exhaust manifolds and NPP?
'16 Jet Black 2SS | A8 | MRC | NPP | NAV |
08-11-2016, 08:07 AM | #3 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
This X-pipe assembly bolts on behind the primary cats and eliminates the secondary cats. It should bolt up to the factory NPP mufflers.
05-08-2017, 02:18 PM | #4 | |
Drives: 2017 1SS/1LE Join Date: Sep 2016
https://www.summitracing.com/parts/vpe-1176 |
10-16-2017, 01:44 PM | #5 |
2016-2017 Camaro SS 6.2L V8, Automatic/ Manual Trans Rear Wheel Drive 2 door. Website Link : http://www.rpidesigns.com/shop/item....06-cat-delete/ |
10-16-2017, 02:26 PM | #6 | |
Drives: 6th. Gen ZL1 Join Date: Jan 2017
https://www.borla.com/products/camar...rt__60606.html |
10-17-2017, 01:36 PM | #7 |
Fixed.
Thanks, for catching that. |
10-19-2017, 05:31 PM | #8 |
10-06-2018, 03:47 PM | #9 |
07-04-2020, 02:10 PM | #10 |
Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
Would the 60607 bolt up to an MBRP axle back on a 2017 SS 1LE? Or would you need an exhaust clamp reducer 3" to 2.75"?
07-04-2020, 06:03 PM | #11 |
Drives: 2017 NGM 1SS MRC NPP Join Date: Feb 2017
These in stock?! The 60606? If so I’ll order right now, I know this post is a little on the older side...
Mamo PTB /Borla ATAK NPP /Carbon Fiber lip/ZL1 side skirts/ Black Bow ties/Husky Mats/ Mishimoto CC /BMR strut tower brace/ZL-1 License relocation/Rock guards
05-09-2021, 09:22 AM | #12 | |
Drives: 2018 Camaro Join Date: Apr 2021
It says discontinued, how would I purchase? |
11-10-2021, 04:00 AM | #13 |
Drives: '21 M6 1SS 1LE Join Date: Aug 2021
perhaps there's an issue with your site but like whynotlikemike inferred, there's no buy now button
07-24-2022, 01:00 PM | #14 |
