03-09-2016, 06:01 PM | #1 |
Drives: 16 camaro M6/ 18 ZL1 camaro A10 Join Date: Nov 2015
ANYONE WITH HP TUNER TRIED TWEAKING FACTORY TUNE
I'M NEW TO TUNING (SELF TAUGHT THROUGH TRIAL AND ERROR BUT NOT A WANTABE MECHANIC) AND PURCHASED A HP TUNER FOR MY 2016 CAMARO WHICH I HAVE ALREADY TURNED THE SKIP SHIFT OFF, SMOOTHED OUT THE SPARK GRAPH WHICH IS ALL OVER ORGINALLY AND SET THE IDLE UP ALITTLE TO PULL OFF EASIER. I ALSO PORTED MY THROTTLE BODY OUT. I DON'T HAVE A DYNO BUT FROM THE SEAT OF THE PANTS IT REALLY WOKE IT UP AND THIS IS ALL ON 89 OCTANE WHICH IS A NO NO BUT THAT'S WHAT WE HAVE AT HOME IN THE IN OUR OWN STORAGE TANK. I WANT TO TRY SOME 93 OCTANE AND SEE IF IT'S BETTER YET.
JUST WANTED TO SEE IF ANYONE IS TWEAKING THERE'S WITH HP TUNER AND IF SO WHAT CHANGED DID YOU MAKE. THANKS |
03-09-2016, 08:30 PM | #2 |
Can you see if you can enable AFM
03-10-2016, 07:19 AM | #3 |
MY CAMARO DOESN'T HAVE AFM BECAUSE IT IS A MANUAL AND ON THE HP TUNER IT DOESN'T OFFER IT AS FAR AS I CAN SEE AS SOMETHING TO TURN ON OR OFF BUT ON AN AUTOMATIC IT MIGHT. THE LT1 DOES HAVE DISPLACEMENT ON DEMAND AND YOU CAN CHANGE THE SETTINGS ON THAT ALONG WITH TURNING IT OFF. THE AFM SYSTEM REQUIRES MECHANICAL PARTS TO MAKE IT WORK LIKE AFM LIFTERS AND A AFM VALLEY PLATE THAT REDIRECTS OIL TO THE LIFTERS SO I DON'T THINK YOU CAN TURN IT ON WITHOUT THE HARDWARE AND A COMPUTER THAT SUPPORTS IT. I HOPE THIS HELPS.
03-10-2016, 08:33 AM | #4 | |
Many of us here are under the assumption that the afm parts are in the engine. There is only one LT1. Unfortunately not many people here are using hptuners yet. I sold mine but might buy one again |
03-10-2016, 08:16 PM | #5 |
IF YOU WANT TO TWEAK THE DOD THERE ARE SETTING FOR THIS. YOU CAN SET HOW LONG IT STAYS ON AND HOW LONG IT STAYS OFF AND AT WHAT RPM IT GOES OFF FOR PERFORMANCE BUT THE FACTORY DOES HAVE IT SET AT 3800 RPMS (PRETTY SURE WOULD HAVE TO CHECK) TO GO OFF WHICH IS PRETTY HIGH.
03-11-2016, 09:56 AM | #6 | |
03-11-2016, 04:48 PM | #7 |
I DID SOME RESEARCH AND FROM WHAT I FOUND CHEVY IS GOING TO DOD INSTEAD OF AFM BECAUSE IT EASIER TO PUT INTO PLACE BECAUSE IT DOESN'T REQUIRE ANY HARDWARE IT'S SOFTWARE. IF YOU CHECK CHEVY'S PART LOOKUP THE 2015 CORVETTE WITH THE LT1 THAT USED AFM LIFTERS ARE DISCONTINUED WHICH LEADS ME TO BELEIVE THEY ARE ONLY USING DOD ON AUTO'S AND MANUALS. I ATTACHED SOME PICTURES BELOW TO SHOW THE SETTINGS FOR DOD (STOCK SETTINGS) WHICH THEY ACT THE SAME WAY AS AFM WITHOUT THE LIFTERS AND VALLEY PLATE AS FAR AS I CAN TELL. I HOPE THIS HELPS, I'M NO EXPERT, WORKING OFF WHAT I SEE AND READ.
03-11-2016, 06:57 PM | #8 |
Thank you. Appreciate the pictures too, they are a big help.
03-12-2016, 11:41 AM | #9 |
Drives: 2016 camaro ss Join Date: Oct 2010
DOD and AFM are the same thing. Chevy is not going to DOD. DOD is just what it was called first, then it was renamed AFM. No parts have been discontinued, maybe updated or a new part number but I haven't looked into it. The AFM lifters are still being used and will be for a long time into the foreseeable future. This isn't just a software thing. The reason your tables say DOD instead of AFM is because it's the same thing. I've got an auto and the tables say DOD too. It's the same thing
https://en.m.wikipedia.org/wiki/Active_Fuel_Management
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
03-12-2016, 12:37 PM | #10 |
Drives: 2016 Camaro SS - A8, MRC, NPP Join Date: Apr 2009
So has anyone actually tuned a car yet? The only company I've seen offering a tuner with pre loaded tunes is Livernois.
Delivered: 2016 SS Nightfall Grey - 1SS, MRC, NPP, A8
Current Vehicle: 2001 C5 Corvette Previous Cars: 2009 C6 Z06 2008 C6 Z51 PKG |
03-12-2016, 02:25 PM | #11 |
Drives: 2016 Camaro 1SS A8 Join Date: Jan 2016
We played with the tune on our stock '16 SS before we converted it to E85 and put the converter in it etc. We were only able to be pick 6-8hp from the stock tune on 91. Tuned fairly aggressively from the factory. Trans tuning is limited for the A8, and we are having problems getting our aftermarket billet converter to lock up. We have to download 3.0 and see what the new changes are.
On E85 it is a whole difference story, we picked up 33rwhp and 25rwtq from being able to take advantage of the compression and throwing more timing at it.
2016 1SS A8
7.9 @ 90.79 Stock with a tire 7.20 @ 94.71 LBO getting kicked out Now tuned on E85, CA Performance Test pipes & Circle 4C 3800 stall shooting for low 7's next time out. |
03-12-2016, 06:19 PM | #12 |
after looking in the performance 2016 book at the lt1 block I see that I was wrong about there not being anything mechanical on afm/dod because the block has provisions for afm/dod. Thanks jimmypop13 for your link because I like to correct my mistakes.
03-12-2016, 06:29 PM | #13 |
If anyone on here has a hp tuner and has a dyno would they be willing to try tunes if we attach them on here, just asking. I know that people pay for this service but there might be a chance someone has something that might work better then some can tune. I can understand if no one wants to do this but I'm just throwing it out there. Thanks
