02-15-2016, 09:01 AM | #1 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
1LE tire size question
I am curious as to why the 1LE, in either configuration, didn't follow the square setup?
I haven't seen any mention through any of the other threads.
02-15-2016, 09:07 AM | #2 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
I imagine that a combination of better chassis and the E-LSD helps the car avoid pushing that can sometimes be caused by rear tires being a lot wider than the fronts.
So a square setup isn't needed. However I would be interested in seeing if 305's can be fit up front to see if it creates better turn in or if it creates an oversteer situation.
MJK3888 Instagram Link
02-15-2016, 09:21 AM | #3 | |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
PS: To me having a car that acted neutral (as little as possible oversteer and understeer) would be the desired goal, no matter how you went about getting it. |
02-15-2016, 09:41 AM | #4 | |
"M1SS1LE"
Quite simply the 6th gen platform may not have this issue. It probably has a better balance. So square tires aren't needed. So the people who preached to you about the square setup are right in reference to the 5th gen, but it seems it may not be on the 6th gen. The E-LSD could be the tech allowing the car to still rotate with larger rear tires similar to the 911 just not as drastic as using rear steer.
02-15-2016, 10:09 AM | #5 |
The sway bars are the easiest tool used to offset under-steer created by the staggered tires. Look at the sway bar specs between the gen 5 1LE and ZL1, although the ZL1 has staggered tires it doesn't have under-steer issues because the sway bars were setup to deal with it. The 1LE sway bars were designed for square tires. If you have a gen5 SS and want under-steer gone with stock staggered wheels you want to use the ZL1 sway bars. If you change your SS to square tires, use the 1LE swaybars.
I have not seen the specs for the sway bars on the 1LE but I imagine they are different then the SS or they have the same bars which means the SS doesn't have much under-steer to begin with. Can anyone confirm the sway bar specs between the two?
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
02-15-2016, 10:14 AM | #6 | |
Drives: 1992 Z28 1LE; 2015 Zl1 Join Date: Mar 2009
The 5th gen had a square setup to help reduce the understeer present in the regular SS. The 6th gen was more neutral to begin with and this wasn't a concern.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x 1991 Camaro Z28- 1991 Camaro Z28 1LE- 1992 Camaro Z28 1LE- 25th anniversary 2015 Camaro ZL1 |
02-15-2016, 01:24 PM | #7 |
Would anybody know what the offset of the rims would be? Just curious to see if they would be similar to the 5th gen 1LE???
02-15-2016, 01:25 PM | #8 | |
"M1SS1LE"
That is also a way to help reduce understeer in a car, but I think we are comparing apples and oranges when we talk about how they went about tuning a 4,100lb 580HP car and a 3,800lb 426HP car. Also lets not forget that the ZL1 had MRC and the 1LE did not. A lot of differences between the two cars.
02-15-2016, 01:30 PM | #9 | |
02-15-2016, 01:34 PM | #10 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
I would agree with all that's been said above, and just add this...
The square set-up also provided the ability to use various tire and wheel set-ups. The staggered set-ups seemed to have limited choices for track (or street) tires that give you the same height and all around. You can even rotate tires for longer life, unlike staggered. I'm sure the 6thGen's staggered set-up is an improvement over the 5th's, but I hope going square on the 6th is also doable, and won't upset MRC or Stabilitrak. Aftermarket tire and wheel choices will be more of an easier option as well. |
02-15-2016, 01:54 PM | #11 | |
"M1SS1LE"
Sometimes it's a shock when those kind of people learn that they may not know it all. Sometimes entertaining sometimes not so much. Always makes me smile though. We are all here to learn and discuss things. That's why I join forums. To learn. Not to teach. I have done a lot of searching here and on other forums to learn about E-LSD, PDR, Performance Traction Management. I enjoy learning about the wild stuff that engineers are doing with affordable cars now.
02-15-2016, 02:20 PM | #12 | |
Drives: 22 ZL1 1LE Join Date: Nov 2014
02-15-2016, 02:31 PM | #13 |
Drives: suzuki Join Date: Apr 2015
02-15-2016, 02:54 PM | #14 | |
"M1SS1LE"
I likely will just keep to original setup until the goodyears are worn then I may see if I can fit 295F/315R Michelin Sport Cups to replace the standard 285F/305R we shall see in time.
