02-10-2016, 08:21 PM | #1 |
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo Join Date: Jan 2011
Anyone know if the 2015 Brembo Carbon ceramic brake kit fits the 2013 1LE?
I'm curious to know if this can be done with no major modifications while I still use my oem rims . And if anyone know around how much the kit will be . Thanks
02-10-2016, 08:25 PM | #2 |
Asskicker
Drives: '15 Camaro Blue Velvet Metallic 1le Join Date: Feb 2016
Well they fit under the 19" Z28 wheels, there shouldn't be any issue with fitment inside the 1LE wheels
edit:http://www.motortrend.com/news/on-ch...-make-the-car/ Last edited by Gregss1le; 02-12-2016 at 01:47 PM. |
02-10-2016, 09:12 PM | #3 | |
Drives: 2014 1SS 1/LE Join Date: Feb 2016
02-11-2016, 10:08 PM | #4 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
Full drop in, front and rear, no mods required. Cheapest I saw was ebay, $8,000 for all four calipers and rotors. You will however not have working pad wear sensors since our cars and brake module dont have necessary wires and board modifications.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
02-12-2016, 07:24 AM | #5 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Did YOU install these as one of the mods over the winter!
02-13-2016, 10:23 AM | #6 |
Sweet man, now ur talking serious stopping upgrade.
02-13-2016, 11:34 AM | #7 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Yikes, $8K! Anyone compared the performance of that set up vs. Stop Tech or BBK, Wilwood, etc? I'm all for awesome stopping power, but I have to balance performance vs. cost.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
02-13-2016, 12:25 PM | #8 |
Asskicker
found this today:
http://www.ebay.com/itm/Brembo-OEM-G...dWsMo3&vxp=mtr might be able to piece it together for cheaper, I paid 72 bucks for rear brembo CTSV calipers that I put on my 1991 camaro. Just have to look and pull the trigger when you find a good deal. |
02-13-2016, 02:02 PM | #9 | |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
These Carbon Ceramic setups are ok for street and some track use but a good race pad/iron setup will still be them. Remember these are not carbon-carbon brakes like you see on the F1/ALMS/LMP1 cars. |
02-13-2016, 07:12 PM | #10 |
Resident nomad
That's what I was thinking. I've had great results with StopTech on a Viper and a Z06. Just not too familiar with the GM carbon option.
Sold:
02-14-2016, 09:37 AM | #11 |
I am fairly certain there is no better brake option for a 1LE than the z/28 carbon brakes. Even if you upgrade to a stoptech system with two pc calipers (not good) the rotors are stupid expensive in 6 piston sizes. Plus the mass savings with the CCMs is an enhancement too. Dont get me wrong, there is iron set ups that could perform as good but wilwood, racing brake etc shouldnt even be mentioned in track applications. Stoptechs would cost close to this money too in 6 piston sizes and as one of our friends found out AP racing front only was 4000 bucks in cast iron.... smaller output system.
Well, that is outside of the CTS-V/ZL1 6 piston front system for the money.
02-14-2016, 09:51 AM | #12 | |
Drives: '16 C7 Z51 Join Date: May 2012
FYI, the front StopTech system cost $2600 shipped, and you don't really need the rears. CC rotors only last ~3x more than steel (per what I know from C6 Z06/Z07), and the rotors' surface will also become abrasive past mid-life, and will start eating brake pads at twice the pace, which are also $600. Besides the weight advantage, there is seriously no other advantage, and that advantage is also not as high as you think when you switch to narrow annulus StopTech or similar BBKs.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
02-14-2016, 10:17 AM | #13 |
Drives: 15 Lexus RCF, 17 Vette Grand Sport Join Date: Apr 2013
Mgizzle, I have no idea where you are getting your information. People who consistently track Porsches corvettes etc on a consistent basis find that switching to steel rotors is the way to go due to the crazy cost of replacement in carbon ceramics. In addition, you keep bringing up the size of the AP racing for 4K and state that they won't have as much thermal capacity because the size of the caliper is slightly smaller then the ctsv setup. These seems only like a personal opinion and not a fact. The AP racing system is a race system with a fully forged caliper stainless vented Pistons anti knock back springs and that's before we even get into the rotor. I see you work for GM, unless you have a business card with the word engineer on it, please state things as opinions and not facts
2013 Summit 1SS 1LE w/NPP, SW 1 7/8" Long Tube Headers, CAI Intake, Ported TB, Cammotion 224/232 113 LSA, BTR Valvetrain, Melling Oil Pump, 468 HP 423, Apex Catch Can, Tank Plates, RPM 4 Point Roll Bar with SCCA/NASA Cross Brace, Schroth 6 Point Han's Harness, OMP WRC Front Seats, F.M.T Trailing Arms, F.M.T Solid Aluminum Subframe Bushings, Moreno Motorsports Camber Plates, BMR Bushings Front and Rear, Essex/AP Racing Radi-Cal Endurance Front Brakes, Quantum Brake Cooling Ducts, ZL1 Rockers, ZL1 Air Deflectors, Heritage Grill, Pfadt Springs.
02-14-2016, 10:55 AM | #14 | |
By the way, here is one of my posts regarding weights. From my build thread:
