Old 12-26-2015, 11:03 PM   #1
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Lowering springs didn't lower car?
Hey guys just got the BMR 1.5 inch lowering springs from phastek and we put them on this afternoon. The front end didn't get any lower while the rear end only dropped half an inch. Any thoughts? I know they have to settle and all but should you see a little bit of difference out of the front?
White shoes at the black show
AmericanMuscleCars is offline   Reply With Quote
Old 12-26-2015, 11:09 PM   #2
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
did you time your bushings?
2011 2SS/RS built 8/24/10
Old 12-27-2015, 06:45 AM   #3
chozn4service
chozn4service's Avatar
Drives: 2016 SS w/2SS A8 Blue Velvet
Should have seen an immediate drop in the ride height. I always like to take a yard stick and measure from the ground up to the fender well lip, before and after. Typically once the springs are installed, the bushings at certain points are not tightened fully to allow them to be timed or re-cocked. This is done by driving the car around just a short distance and then tightening them back properly. This gives you a great or better ride. If you haven't done this you should and you also need an alignment but you should have seen a difference on all four corners.
Never grow up, it's a trap!
chozn4service is offline   Reply With Quote
Old 12-27-2015, 11:27 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Have you moved the car since you put it back on the ground? Timed the bushings?
