dave@hennessey
Old 11-14-2015, 10:28 PM   #1
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
CEL Doesn't Work
Has anyone had the problem of CEL not working? As in the bulb doesn't work? If so, what did you have to do to fix it?
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 11-15-2015, 07:39 PM   #2
TooCool5
TooCool5's Avatar
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP
Had this problem on my sons eclypse. Put the ECU harness on and off a few times and it started working and got the code.
Probably and electrical connection somewhere.
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
TooCool5 is offline   Reply With Quote
Old 11-16-2015, 03:50 PM   #3
2LSCamaroSTL
2LSCamaroSTL's Avatar
Drives: 2LS Black with IO stripes
Mine doesn't work either...
K&N CAI, Gloss Black and Orange bow ties, IO brake calipers, RS headlights.
2LSCamaroSTL is offline   Reply With Quote
Old 11-16-2015, 06:36 PM   #4
TooCool5
TooCool5's Avatar
Try it, what do ya got to loose?
Old 11-16-2015, 07:46 PM   #5
Reineke
Drives: 2010 SW Camaro 2SS RS 6M
When you first cycle the key in the ignition, the panel does a bulb test. See if the CEL illuminates at that time. If it doesn't, then the led/bulb is probably bad. Without seeing the PCB, you may be able to remove the bad and solder in a new one.
Reineke is offline   Reply With Quote
Old 11-17-2015, 10:34 AM   #6
lscamaro
lscamaro's Avatar
No, the bulb does not come on during the startup cycle. Is there a diy on how to do this?
Old 11-19-2015, 01:45 PM   #7
TooCool5
TooCool5's Avatar
There is a DIY on pulling the cluster and bezel. Its in that section.
Old 11-19-2015, 04:57 PM   #8
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
If the CEL indicator does not turn on during the self check it is an LED/internal wiring issue. The IPC does a bulb check that is independent of the ECM control.
JerTM is offline   Reply With Quote
Old 11-21-2015, 02:49 PM   #9
TooCool5
TooCool5's Avatar
Can you read any codes?
