10-26-2015, 06:13 AM | #1 |
Drives: 2015 zl1 Join Date: May 2015
New ZL1 acting strange
Took a ride in the zl1 yesterday and stopped and put gas in it and then drove about 5 miles and shut car off and sat for about 10 min and drove about 5 more miles shut car off and went into the store when I came back out I started the car it said " reduced engine power" "stabilitrac" and it was shaking so hard I thought it was getting ready to throw the s/c off top the engine! So I immediately turned car off waited and restarted to same thing......so I waited 3 or 4 min restarted it ran and sounded great with exception of CEL being on. I drove it straight home and that's were she stayed and I will obviously contact the dealer today ( even though there past practice is very very unimpressive) but I wondered if any of you LS/Camaro veterans can give me a little insight? Thank you very much.
Car is 100% stock 250 miles on it. |
10-26-2015, 06:44 AM | #2 |
Some new cars have had issues with the ECM and the connections going to it. The CEL light will give the code and it should be easy to resolve. The pins in the ECM connector have also been a problem on some new cars. Other than that, I am sure they will check the main engine harness and associated ground connections.
10-26-2015, 08:08 AM | #3 |
Drives: 2015 ZL1 Join Date: May 2012
My car did the same thing. They replaced the ECM, and put a new battery in the car. Its been running fine since.
2013 Camaro ZL1,Victory Red # 441....SOLD
2013 Camaro ZL1, Summit White # 3071...SOLD 2015 Camaro ZL1, Summit White # 1325 Rotofab Cai,PCM cc,Kooks Headers,Cats delete,MF X pipe, ZLWin cam,upper/lower, Lingenfelter hx,715 rwhp,646 rwtq, BMR 1.25 Springs, Varro VD01 Wheels, Last edited by RJ111; 10-26-2015 at 08:09 AM. Reason: . |
10-26-2015, 08:36 AM | #4 |
This may be off subject but since we are talking about connections I was laying under it spraying the belly off the other day and right inside passenger rear wheel there is exposed connections/wiring is that normal? Looks like it could easily be water damaged and I don't remember my 1le having this.
10-26-2015, 09:19 AM | #5 |
yes...the connections near the fuel tank and suspension wiring appear to be "unprotected". The magnetic shocks that your 1LE didn't have is the major difference.
10-26-2015, 09:39 AM | #6 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
The car has only 250 miles in it and your underneath spraying water... I'm sure you just sprayed some electrical connection and now the car acting all funny.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
10-26-2015, 11:25 AM | #7 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
I'm going to say it anyway but that is way too OCD. The only underside of a vehicle I ever cleaned was the Fire Engine on a formal inspection. Now you are second guessing GM engineers and the wiring. If it was damaged by water don't you think they would know since the car has over 5 years, and thousands of owners Good luck with that.
10-26-2015, 11:34 AM | #8 |
Haha no that was a few days ago I was underneath washing .....I'm new to FI cars but not cars all together. I did get a good laugh out of that tho. And also yoh are correct I no that they are different animals but though maybe these stood out more because they were unprotected and the bright colors but I honestly did not think of the extra components due to the magnetic ride ( which is soooooo nice) . Thank you all very much though this once again is the reason I like Camaro5 for the knowledge of others that are willing to share! Even if I get harassed now and then haha and I will because I am a very curious person who likes to educate so I ask plenty of questions stupid or not!
10-26-2015, 12:02 PM | #9 | |
10-26-2015, 12:15 PM | #10 |
HTWEELZ
Drives: 2013 2SS Hot Wheels Edition Join Date: Jan 2013
Same thing happened to my brother in-laws car. The replaced the ECM and the battery, been good since. Seems to be that they had some bad ECM's in a batch of them.
2013 2SS Hot Wheels Edition 727 of 1524
w/ Dual Mode Performance Exhaust, Nav, and Performance Shifter. DELIVERED APRIL 22nd, 2013 and enjoying every minute since! Mods: Cold Air Inductions CAI, CNC Ported Throttle Body, Elite Engineering Oil Catch Can, Smoked Spyder LED Tail Lights, 12" JBL Sub, JBL Amp, Stealth Sub Box, American Racing LT headers and hi-flo cats, Tuned by Davenport, Custom painted interior pieces, Custom painted hood liner and trunk liner, Niche Targa M-130 wheels, LED side markers |
10-26-2015, 12:27 PM | #11 |
Hopefully that will fix it. I am supposed to drop it off to them so I will see soon. Thanks for all the help
10-26-2015, 12:42 PM | #12 |
Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
The main power wire at the fuse box had a loose nut. It was creating all kinds of strange issues, service stabilitrack , car shut off after moving about ten feet, the center dic would tell me to roll up and down drivers window. The dealer replaced the fuse box and positive cable. I have had no issues since the fix.
10-26-2015, 12:43 PM | #13 | |
10-26-2015, 01:32 PM | #14 | |
Go fast, please.
