Go Back   Chevrolet Corvette Stingray C7 Forum > Marketplace > Commercial Classifieds Marketplace > Bolt-Ons, Tunes, Engine Internals
Old 10-12-2015, 10:56 PM   #1
Ivan @ Southwest Speed
Drives: '15 Z06, '01 NBM SS, '97 SS
aFe Momentum Air Intake System For C7 ** FREE SHIPPING ** LOW PRICE GUARANTEE!!
aFe is proud to introduce the all new Momentum sealed intake system for the 2014 Chevrolet Corvette (C7) with the V8-6.2L engine. This all new Momentum intake system resulted in 18 horsepower and 22 lbs. x ft. torque and outflows the factory intake by 42%. This system is superior in every way, from the one-piece sealed housing, to the massive air filter, roto-molded tube w/ built-in resonance chamber and premium hardware. This system uses a CAD designed, dyno-tuned, roto-molded intake tube & housing to achieve maximum power gains while maintaining a perfect fit. This is a direct bolt-on kit and requires no cutting or drilling on OEM parts.
Unique One-Piece Housing w/ Sight Window:
The one-piece sealed housing is used to eliminate the use of multiple components and ensure the coolest air intake charge available. A large clear sight window allows for filter inspection without removal of the air box. The roto-molded housing is made out of black cross-linked polyethylene and mounts directly into the factory location on the fender well to capture the coolest air available from the factory intake tract.
Roto-molded Tube:
This system uses a CAD designed, dyno-tuned, roto-molded intake tube to achieve maximum power gains while maintaining a perfect fit. This tube has a built-in resonance chamber to catch un-wanted air intake noises. Two billet aluminum fittings are mounted on the tube to provide a perfect connection with the factory vacuum lines.
Massive Cone Air Filter:
This Momentum intake system was designed around the largest filter possible to allow maximum performance and filtration. This cone filter has a massive 7" oval flange and is 9-1/2" tall Pro 5R filter media. The Pro 5R performance air filter features 5-layers of progressively finer mesh cotton gauze oiled media and is constructed with 100% polyurethane frame for long life and multiple cleaning cycles.
Premium Hardware:
Premium stainless steel T-bolt clamps and a reinforced silicone hump coupler are used for strength and durability while also providing the most secure installation available. Momentum intakes are designed with fewer parts for a quick and simple installation.
Proven Results:
After a rigorous design and testing phase, the results are in. The Momentum air intake system outflowed the factory intake by 42% and resulted in 18 additional horsepower and 22 lbs. x ft. torque.
Power, Protection and Simplicity.
Find it for less, and we'll beat it!
*Note: This intake system is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
Ivan @ Southwest Speed is offline   Reply With Quote
Old 11-29-2015, 01:16 PM   #2
Use promo code "NOVEMBER" to get an additional 10% off our already low price from our website.
Take a look around....lots of ridiculous deals to be had!!
Thank you all for the support and orders.
