Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 08-05-2015, 09:05 AM   #1
xc_SS/RS
Drives: 2010 Camaro SS/RS
2014 hood vent airflow
So I've got a 2010 Camaro SS and I've been thinking about adding the 2014 hood vent to my car but I've got a question about airflow. They put the hood vent onto the 2014-2015 to reduce lift, reduce underwood temps etc. and I was thinking that my Vararam intake would not allow as much air to flow out of the vent. Would this be a problem? I know that hot air will still vent but I'm wondering if it will be a decent amount less? Also it seems that the drip tray will empty right on top of the intake and I wonder if that will pose a problem as well?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-05-2015, 09:27 AM   #2
Jsmith18
Jsmith18's Avatar
Drives: 2013 Camaro LFX
I think the driptray will drain in front of the intake, where the hood latch is(not to say some residual water may get on it). So I'm pretty sure you would be fine there. Not sure about the other information but the vents definitely look awesome! Thinking about doing it myself!
Jsmith18 is offline   Reply With Quote
Old 08-05-2015, 01:04 PM   #3
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
The hood vent tray drips onto the top of the radiator/fan shroud.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-05-2015, 01:53 PM   #4
xc_SS/RS
Yeah and with my radiator leaned back to fit the vararam in there it will drip onto the intake. It looks like it would just run off the sides of the intake so that isn't much of an issue as there still won't be a chance of it getting sucked into the intake. What I'm mainly worried about is not being able to fully utilize the cooling effect and reduction in front end lift due to the intake covering nearly half of the vents. So if the intake being where it is in relation to the vent I need to think about a new intake or potentially the ZL1 hood/TL1 insert.
Am I on the right track with this one?
2010 2SS/RS
Old 08-05-2015, 04:29 PM   #5
White_SS/RS
Drives: 14 1LE
I think the ZL1 hood extractor sits even lower than the 14-15 style. I think you'll be ok with the 14-15 style.
LMS Engineering
Old 08-14-2015, 09:01 AM   #6
Speedfreak391
One man Army
Speedfreak391's Avatar
Drives: 1987 Iroc Players car
Check out the hex-vents also. If you are just looking to relieve the heat.
1987 Iroc-Z with a turbo 5.3, T-56, Moser 9", and lots of other goodies.
http://www.mifbody.com/vbulletin/sho...87-IROC/page24
2010 Camaro 2SS/RS with a K&N cold air Stainless Power headers, Magnaflow cat-back, staggered TSW Nurburgring's just a great daily driver.
Speedfreak391 is offline   Reply With Quote
Old 03-01-2016, 04:26 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I picked up all the 2014 hood vent parts too for my car.
As soon as we can I'll have my body shop buddy install it and I'll share if the car runs cooler (which is the goal).
I already have a 160 stat.
No Hex Vents for me, I don't think that system would vent heat as well.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 03-01-2016, 05:57 PM   #8
RichSS2006
RichSS2006's Avatar
Drives: 2010 2SSRS
I recently installed the vent and rain tray. It dumps water out just ahead of the radiator, but behind the hood latch. I don't think the rain tray will work with the VRam intake. Too much going on there fighting for space. I will say that the tray drains away water real good. My engine did not get wet during a weekend washing.
No longer stock, but oooh so much more fun!
RichSS2006 is offline   Reply With Quote
Old 03-01-2016, 06:17 PM   #9
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
The hood vent works mostly by creating a vacuum, or low pressure area, inside the vent as the air rushes by it. Things partially in the way won't really matter a much as you think, because the vacuum is still being created.
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
Old 03-01-2016, 10:01 PM   #10
Scotty D2014
Drives: 2014 SS1-1le Crystal red metallic
I took the drain tray off .. You can see the heat coming out of it .. I'm sure it must help the engine bay
Scotty D2014 is offline   Reply With Quote
Old 03-01-2016, 10:05 PM   #11
xc_SS/RS
Good point and I didn't even think of that
Yeah the hex vents look cool but I also don't think they would do much for heat.
I still need to do this mod as well.... Maybe a summer project
2010 2SS/RS
Old 03-02-2016, 05:15 AM   #12
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
I had the older version of the HEX vents and ran them without the tray. Heat poured out of them even when at a standstill.
mp51998 is offline   Reply With Quote
Old 03-02-2016, 10:27 AM   #13
wernergmhtp
wernergmhtp's Avatar
Drives: 2014 Camaro 1SS/RS A6
Would be interested to hear if anyone has tried drip tray intact vs. drip tray removed and whether this had any effect on engine temps on a road course.
Chris Werner
Author, "How to Rebuild GM LS-Series Engines"
Contributing Editor, GM High-Tech Performance (1998-2014)
wernergmhtp is offline   Reply With Quote
Old 03-02-2016, 01:34 PM   #14
Pro Stock John
Writer
I have a Vararam airbox would that be a problem?
PROJECT HEAVY CHEVY
