Old 07-09-2015, 04:40 PM   #1
xrivera91
xrivera91's Avatar
Drives: 2015 Camaro 2ss
Check engine light
After having a small leak in my brand new exhaust fixed (pipes weren't connected properly) which was an easy fix. Now my check engine light has turned on. Haven't done anything to it except fill it with premium fuel after learning my dealership lied about what fuel I need. Any suggestions? Sorry if this is not in the right spot. And yes I tried to search.
xrivera91 is offline   Reply With Quote
Old 07-09-2015, 05:00 PM   #2
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
nobody can help you unless you have the car scanned and share the code. I'm guessing since they took off the exhaust, you have an issue in the cat sensor or wiring.
go back to dealer.
maddoggyusa is offline   Reply With Quote
Old 07-09-2015, 05:55 PM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
there is also a thread about the fuse pull to reset the fuel tables that may help you too. And make sure the gas cap is on tight....
Old 07-09-2015, 06:07 PM   #4
Mortious
Ammo
Mortious's Avatar
Drives: 2010 Camaro 2SS/RS (LS3 M6)
Muffler bearings not rotated properly....
Mortious is offline   Reply With Quote
Old 07-09-2015, 06:21 PM   #5
Dizzy82
Dizzy82's Avatar
Stop by an Autozone, O'reiles, or PepBoys and get it scanned. And buy yourself a cheap OBDII scanner as well. Unless we know the codes we can't help you.
Old 07-09-2015, 10:16 PM   #6
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
I bought the cheapest OBDII reader, $79.00. Not only can it translate the code to the corresponding number but it can also reset the error so the light goes out. This is assuming the error has been corrected. Do yourself a favor and spend the $79.99-$85.00 to read the code and get on with your life. You could even read your friends and families' codes for a profit.
lawman007 is offline   Reply With Quote
Old 07-09-2015, 10:34 PM   #7
Squillo
Drives: 2013 Camaro 2SS/RS BRM LS3
OP, you should check the blinker fluid.
Or you can go get an OBDII code reader like Lawman suggested and be able to read and clear your own codes. It will pay for itself the first time you use it.
Squillo is offline   Reply With Quote
Old 07-09-2015, 10:44 PM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you still have stock catalytic converters and exhaust manifolds? Do the fuse pull and if you already fixed the leak in the exhaust the code might go away. get it scanned for free at the auto parts store right it down and clear it. might not come back.
Old 07-10-2015, 08:58 AM   #9
xrivera91
xrivera91's Avatar
Wow guys thanks a lot I'm going to buy the diagnosis thing which seems like a great investment. Ordering online though as it's cheaper. Will also run to auto shop and have the diagnostic done to see what it is I'll let you all know soon. Hopefully it's a quick fix.
Old 07-10-2015, 09:10 AM   #10
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Sale on Blinker Fluid this week only:
kmarshall2121 is offline   Reply With Quote
Old 07-10-2015, 10:56 AM   #11
xrivera91
xrivera91's Avatar
go back to dealer.
So I just got a P0150 read on the diagnostic which is something with the 02 censor.
Old 07-10-2015, 02:54 PM   #12
Mels RS
Mels RS's Avatar
Drives: 2015 2LT/RS Vert
I think the blinkers on the later models are pneumatic.
Just need to recharge the accumulator with compressed air.
Mel
2015 2LT/RS 'Vert, RRM/Blk
Designated Airworthiness Inspector; specializing in Amateur-Built and Light-Sport Aircraft. USAF Vet.
<n168tx(at)flytx.net>
Mels RS is offline   Reply With Quote
Old 07-10-2015, 03:02 PM   #13
hazy
Drives: 2011 2SS/RS
man, don't go buy a scanner for $80.
Get on amazon and get THIS if you have an Android phone, or THIS if you have an iphone.
Then, go to your Play Store (android) or App Store (iphone)
Android: buy Torque Pro for 4.95
iphone: buy DashCommand for 9.99
Total cost:
-Android: $28.94 (+ any tax you may have to pay)
-iphone: $26.98 (+ any tax...)
Now you can pull codes any time, any place. Not to mention that both of these apps have some really cool features that will allow you to monitor whatever parameters you want....get a windshield mount for your phone and go to town!
hazy is offline   Reply With Quote
Old 07-10-2015, 03:09 PM   #14
pickwithaustin
pickwithaustin's Avatar
Drives: 2011 Camaro 2SS/RS Convertible and:
Pull up Torque on your cell phone and read the code. Try doing a reset.
I can't believe everyone doesn't have this... if they own a phone.
Currently in my Garage:
2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i
pickwithaustin is offline   Reply With Quote
