TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 06-28-2015, 08:04 PM   #1
cal45
cal45's Avatar
Drives: 2015 Blue Velvet Metallic ZL1
Pulley upgrade complete ..done for now..maybe
Ok, earlier this month I had the ATI 10% crank and damper installed (already had the RotoFab cai in) w/tune...it dyno'd 548 RWHP, 538 RWTQ
Today, had the Lingenfelter 2.55 upper w/hub, ID850 injectors, and NGK TR7IX plugs installed with tune....now at 15psi.
So, for now I'm done....will probably get a dyno run in the next few weeks to see what the gains were from above.
Like to give a shout out to Nomad Mobile Tuning & Performance as Matthew & Jimmy did a great job working all day to get this just right.
cal45 is offline   Reply With Quote
Old 06-28-2015, 08:11 PM   #2
big dave
Drives: 2017 ZL1
How did it feel after the first round of mods? I'm considering a similar setup. Did you have a stock dyno run for comparison?
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 06-28-2015, 08:49 PM   #3
cal45
cal45's Avatar
After the 1st round w/the lower & tune, it really woke up the car and made it feel (to me), what it should have from the factory. The boost was in the 11-12 psi range. No baseline dyno as the work was done in my garage.
Old 06-28-2015, 09:08 PM   #4
big dave
Drives: 2017 ZL1
You're probably right, maybe the ZL1 should've come with more hp from the factory. I guess at the time is was the most powerful pony car, though it didn't last long. It's still a quick car from the factory but being a heavyweight keeps it from being even quicker.
Old 06-29-2015, 06:02 AM   #5
cal45
cal45's Avatar
Agree with you in regards when the ZL1 first came out in 2012, it was at the top for American HP (but not for long). As stock, the car is sneaky fast - meaning that it doesn't throw you back in your seat but before you know it, you're going faster than you thought as the car handles so well. Adding the lower 10% pulley w/a tune really makes a difference. I would have been ok stopping there but I planned to do both pulley swaps but didn't realize the high cost of the ID850 injectors....so I wound up doing them (pulleys) one at a time as I needed to build up my mod fund.....it also gives me a good gauge on the gains that each pulley provides.
Old 06-29-2015, 06:40 AM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Corvette Camaro tuner in Tampa Orlando
The LSA really respond well to boost, but don't get crazy with it and the car will be fine. Most of my ZL1 clients do the intake, throttle body, headers, Injectors, 2.55 pulley and the Tampa Tuning dyno tuning, and are between 580-600 RWHP with most at the 590 RWHP level. Its fun street car power with no drivable issues.
Add the lower pulley and your at 620 to 640 RWHP and a mid 10 second Camaro with A/C to pick up the kids after school with. Cant beat that.
Tampa Tuning is offline   Reply With Quote
Old 06-29-2015, 05:07 PM   #7
big dave
Drives: 2017 ZL1
I noticed you didn't mention an heat exchanger. Is it not necessary at this level? Are these numbers for autos or manuals?
Old 06-29-2015, 06:47 PM   #8
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
What octane is needed to safely run the upper and lower pulley combo?
hairtrigger is offline   Reply With Quote
Old 06-30-2015, 01:40 PM   #9
polarisiq93
polarisiq93's Avatar
Drives: 2013 ZL1 M6
can't wait to see results, I'm thinking of doing the 10% lower to go with my 2.55 upper soon
polarisiq93 is offline   Reply With Quote
Old 06-30-2015, 02:54 PM   #10
cal45
cal45's Avatar
Stay tuned (no pun intended)......I have a Dyno-tuning apt scheduled for tomorrow.
Old 06-30-2015, 03:41 PM   #11
Tampa Tuning
It wont per say help your dyno numbers, but will return the IAT2s to a lower temperature quicker so it wont pull timing. Its a good mod.
93 octane. Just don't kill it with timing and make sure the fuel system is keeping up.
Old 07-01-2015, 04:47 PM   #12
cal45
cal45's Avatar
Well, no Dyno Tune today as the shop (Titan Motorsports) had their bay door open while a quick moving storm hit at lunch time, rain made it inside and hit the computer - so the dyno was unavailable for me at 2PM. They will reschedule with me once they get it back up.
Old 07-01-2015, 06:49 PM   #13
cal45
cal45's Avatar
When I arrived this twin turbo Supra was ahead of me on the Dyno waiting for the computer to boot (it did not)....Titan MS built this and they were figuring on 800 or more RWHP. So as I was waiting took this pic (my ZL1 is up on the right of the frame waiting on next).
Old 07-14-2015, 07:47 PM   #14
Bigkatf1000
Bigkatf1000's Avatar
Drives: 2013 ZL1 Vert
Did you ever get to the dyno with the added 2.55 upper?
Bigkatf1000 is offline   Reply With Quote
