05-11-2015, 01:41 PM | #1 |
Drives: 1969 SS/RS Camaro Join Date: Nov 2013
Tin Sign Giveaway
I've decided to do a little contest on here. Post a picture of your car and list the suspension mods. Don't worry, if yours is stock you're still eligible. I'll draw a winner at random each time the post count for this thread hits 100. I'll go ahead and start it off. Ridetech Level 2 CoilOver system with Tru-Turn and front MuscleBar. |
05-11-2015, 01:47 PM | #2 |
Drives: 2015 SW 1SS/RS 1LE Join Date: Mar 2015
2015 Camaro SS/RS/1LE... stock for now...
05-11-2015, 02:30 PM | #3 |
Drives: 2014 2SS/1LE Join Date: Jul 2013
Stock but have the Ridetech HQ CoilOver to install when the wife isn't looking!
05-11-2015, 03:37 PM | #4 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Everything Ride Tech has for a 5th Gen...
05-12-2015, 03:13 PM | #5 |
Drives: 2012 Camaro 2LS, 05 Trailblazer LS Join Date: Oct 2014
My baby, also stock for now...Unless 600lbs in the trunk counts as a rear lowering mod.
05-12-2015, 03:52 PM | #6 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I have the 1 in. Hotchkins drop all around.
05-12-2015, 03:56 PM | #7 |
Cone Killer
Drives: 2012 SS Join Date: Dec 2013
My mods are: -Pedders XA Coilovers -Hyperco 8" 450 lb/in front springs -Moreno Motorsports camber/caster plates -1LE 27mm rear sway bar -1LE toe rods
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out! |
05-12-2015, 04:04 PM | #8 |
Drives: 2021 Shadow Gray 1LS Join Date: Oct 2011
The '13 just like she came off the assembly line.
05-12-2015, 05:27 PM | #9 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
2014 SS. Stock for now.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
05-12-2015, 09:22 PM | #10 |
Drives: 2010 ecs SS Join Date: Oct 2014
'10 SS. BMR Toe rods, Trailling arms, cradle bushings.
05-12-2015, 09:44 PM | #11 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
BMR lowering springs.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
05-13-2015, 04:08 AM | #12 |
Drives: 2011 Camaro LT with V6 Join Date: Feb 2015
2011 2LT with Eibach Pro-System Lowering Kit.
05-13-2015, 09:14 AM | #13 |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
Stock for the most part suspension wise, couple of appearance mods. |
05-13-2015, 09:16 AM | #14 |
Ed
Everything under the paint non-stock |
