05-05-2015, 09:32 PM | #1 |
Drives: 2010 Camaro 2ss black 21's Join Date: May 2012
Polishing red jewel tricoat
Just wondering if there was anything different about polishing this paint? Does it have a hard or soft clear coat? Any help would be great.
05-06-2015, 10:04 AM | #2 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I had to do some polishing when I picked up my car and I didn't notice anything that I would consider different about it than any other color. It sure does shine like a jewel in the sun, though.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
05-06-2015, 03:31 PM | #3 |
Drives: ? Join Date: Oct 2011
One thing you are going to see is paint transfer on to your pad. That is perfectly normal. Other than that the process is the same. I remember the paint being on the harder side but that was on a vette. I love to tint coat when polished.
05-06-2015, 04:39 PM | #4 |
Drives: 2015 ZL1 Join Date: Mar 2015
Paint should not transfer onto your pad unless you're so abrasive you've gone through (and removed) the clear-coat...
05-06-2015, 05:31 PM | #5 | |
Normally I would say you are correct but not the case with tint coat paint. Trust me. |
05-06-2015, 05:36 PM | #6 |
05-06-2015, 09:04 PM | #7 |
Ok, cool. I stand corrected.
05-06-2015, 09:19 PM | #8 | |
Drives: 2010 2ss/rs m6 Join Date: Mar 2012
I have RJT, I don't get paint transfer to my pad. I use menzerna FG400 |
05-06-2015, 09:53 PM | #9 |
BeckyD Rocks :-)
I've had to do some paint correction on my CRT paint, which is the successor of RJT, and I've had to wet sand in an area by the rear window (rear quarter). Using a very fine grit and starting at 1000 grit and stepping up 1500, then 2000, then 2500 and then finishing at 3000 to get the high spots of the clear coat, I used a white microfiber towel during the process to wipe down between the steps of the wetsanding and there was small amount of red in the towel.
So I would have to agree that there is a certain amount of the tintcoat in the clearcoat.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade. Stage 3 BMR cam, ARH 1 7/8 headers, CAI,
BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings...460 whp...so far....SOLD, but not forgotten! |
05-06-2015, 11:11 PM | #10 |
Drives: The shiny ones. Join Date: Mar 2010
Pretty much all spot on info -
Polishes up the same as any other color, aside from the tiny bit of pigment transfer from the tinted clear. Also looks fantastic when its polished up. Come back with pics for us to drool over when you're done! |
