04-06-2015, 07:55 PM | #1 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
Z/28 Jack Points
I'm about to do the first oil change on the Z and I just realized that the jack points that I use on my SS are covered by plastic. How is everyone jacking up the car?
04-06-2015, 08:06 PM | #2 |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
There are two jack points on each side that are the pinch weld type. If you look you can see them where the areo is molded to expose the jack points. You will need a pinch weld adapter for your jack though, and a very low profile jack.
I think the manual shows a diagram, not sure. Last edited by macalot; 04-06-2015 at 08:19 PM. |
04-06-2015, 08:41 PM | #3 |
There isn't anything in the manual and I can't really see what you're talking about. I'll just check it out again tomorrow. Is there any way to jack it from the sides and squeeze the stands under it?
04-06-2015, 09:34 PM | #4 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
Besides the pinch weld jack points, here's something from the factory that goes into more detail:
04-06-2015, 11:26 PM | #5 |
04-07-2015, 06:05 AM | #6 |
oil change is the same as a C6 Z06. It has two drain plugs in the pan which are clearly marked with an arrow to make sure both plugs are removed. The plug in the normal position only drains about 1-2 quarts. The front plug drains the rest and be prepared for 8-9 quarts from the front plug which obviously drains the tank.
04-08-2015, 06:13 PM | #7 |
Dumb question guys, the right drain plug is directly above the aero and the frame. How am I supposed to drown it without oil going everywhere?
04-08-2015, 09:01 PM | #8 |
take the belly pan off...oil still goes everywhere. There is a solid cross brace directly under the rear drain plug.
04-08-2015, 09:04 PM | #9 |
Yeah I noticed. I crammed a funnel in there and that minimized it
04-08-2015, 11:06 PM | #10 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
