Roto-Fab
Old 03-25-2015, 10:41 AM   #1
steven2680
Drives: ss beast
p300 code random misfire
What's up guy I have a problem with this code p300 I know that is a camaro forum but I have a 2003 chevy tahoe . The code p300 came up I chang spark plug, wires ,I change the plugs back in dec, I don't know what can it be i appreciate any help thanks
steven2680 is offline   Reply With Quote
Old 03-25-2015, 10:58 AM   #2
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Intake gasket, or vacuum leak after the MAF sensor would be where I would look first. P0300 indicates that the misfire is random, and not isolated to a particular cylinder. A bad plug, plug wire, or coil pack would be the same cylinder every time. For example A P0301 code would indicate a misfire on cylinder one.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 03-25-2015, 11:11 AM   #3
steven2680
Drives: ss beast
Cool I just pick up the maf airflow my truck have 118,000 mile the wires was change last night thinking it was the problem but it wasn't the plug was change on December but I just pulled them out from the passenger side and they look White i did the driver side also and are brownish
Old 03-25-2015, 11:29 AM   #4
Jayrcr3
Jayrcr3's Avatar
Sounds like the passenger bank is running lean.
Old 03-25-2015, 11:41 AM   #5
steven2680
Drives: ss beast
I change the maf air flow and still doing the same thing ing
Old 03-25-2015, 02:06 PM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
He said a vacuum leak past the MAF, not the MAF itself. You probably need to replace the intake gaskets if the whole bank is lean.
Old 03-25-2015, 02:18 PM   #7
steven2680
Drives: ss beast
I check all vacuum lines and I haven't seen no leaks. I replace the intake manifold gasket about 5 years agocould the intake manifold gasket be broken already
Old 03-25-2015, 03:32 PM   #8
CamaroCracka
If the leak were from a line, the problem would likely be seen on all cylinders. Since you say the plugs on one bank are white, the like culprit is the intake gasket on that side. You could try spraying starter fluid around the that side of the intake and see if the idle changes. If it does, three is a vacuum leak.
Old 03-25-2015, 04:03 PM   #9
steven2680
Drives: ss beast
I already Spray carburetor cleaner around that area and I haven't seen nothing change
Old 03-25-2015, 10:39 PM   #10
CamaroCracka
I have a similar problem on my truck but only cyl 1 n 6
Just replaced gaskets despite no change when spraying starting fluid
Running a scan on Fri
I'll let u know how it goes
Old 03-26-2015, 05:38 AM   #11
steven2680
Drives: ss beast
Ok think bro since the truck have 118,000 mile I havent done nothing to it but a water pump woo I just order some parts and see which 1 is the part that making the truck misfire I will give a update when I find the problem
Old 03-27-2015, 03:33 PM   #12
CamaroCracka
I put the gaskets on and I can no longer hear the brief whistle from inside the cab when I blip the throttle, but I still get some misfires on 1 & 6, but no longer enough to throw a code.
Old 03-27-2015, 06:09 PM   #13
steven2680
Drives: ss beast
I did sea foam about 2 bottles it got a Lil better but now I have a misfire on cyl 7
Old 03-30-2015, 11:42 AM   #14
CamaroCracka
There was oil on the intake runners. I think I will give that a shot.
