dave@hennessey
Old 03-23-2015, 08:54 PM   #1
camaro1350
camaro1350's Avatar
Drives: 2013 Camaro RS 1LT, 6M
MGW Retro Short Throw Shifter
Just installed my MGW Short Throw Shifter and it looks great and what a difference the shifting is now. I should have done this a long time ago but a then again I wouldn't have gotten the retro style so all is good. It took me a little over 4 hours to install. It wasn't really hard but a couple steps in the installation video made it harder. But overall it wasn't hard just time consuming and I did it on ramps.
camaro1350 is offline   Reply With Quote
Old 03-23-2015, 10:34 PM   #2
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
That's the flat stick style right? Any extra noises from shifter after install?
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 03-23-2015, 10:36 PM   #3
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Very nice. I love my MGW, I wish I hadn't waited so long to this mod.
Old 03-23-2015, 10:54 PM   #4
camaro1350
camaro1350's Avatar
Yes it is. No noise at all. I fixed the boot after I took the picture.
Old 03-24-2015, 02:49 AM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
The video makes it look so easy. Just installed a used MGW yesterday. Love the way it shifts.
CamaroDreams76 is offline   Reply With Quote
Old 03-24-2015, 04:09 AM   #6
Camarotobeornottobe
Drives: 1LE
Slight hijack: I've been waiting for someone to replace the 1LE/ZL1 shifter with the MGW. I'm trying to decide if the upgrade is worth it, since the 1LE shifter is pretty good. Your thoughts on the differences? I'm interested in shift gate, shift effort, noise, etc. Thanks!
Camarotobeornottobe is offline   Reply With Quote
Old 03-24-2015, 08:49 AM   #7
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Is it required that you must lower the transmission to install it? I just bought and MGW Flatstick off a member and it will be here this week and will be installing it myself. I watched MGW's install video and they took a transmission jack and lowered the transmission for more access but I do not have one of those
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 03-24-2015, 10:47 AM   #8
camaro1350
camaro1350's Avatar
No you don't need a tranny jack. All I used was a regular floor jack with a block of wood. Lowered the tranny until it bottomed out and left it there for support. Now a couple hints that the video makes it harder. First, the video showed you to put on the bottom dust cover from the bottom. The problem is that there is not much room and I couldn't get any leverage. I tried to put it on from the top and managed to get it on in less then a minute. Trust me much easier from the top. The second is the rod clips. The video showed you while the tranny was out and I know why now. In the car however, not so easy. The passenger side was pretty easy since the clip is right there. However, the driver side is a pain in the a**. First the hole to put the Allen key in is in the inside and it's blind. You be lucky if you get it in. I just pryed it up with a screwdriver until it finally uncliped praying I didn't break it but it didn't. Overall it was not too bad the dust boot and the drivetside clip was the hardest. Hope this helps
Old 03-24-2015, 11:10 AM   #9
Whitey 22lr
Whitey 22lr's Avatar
Drives: 2010 SS/RS Black, MT
mgw
Thanks for the info!
Whitey
Whitey 22lr is offline   Reply With Quote
Old 03-24-2015, 07:39 PM   #10
menendez1293
I didn't even unbolt the trans brace on my V6. I also didn't have to touch the heat shield. I had quite a bit of room without having to unbolt the trans or heat shield. I also didn't use the included alen key to remove the arms. I found it easier to a small flat tip screw driver
Sent from my Nexus 6 using Tapatalk
Old 03-24-2015, 08:38 PM   #11
bionick
bionick's Avatar
Thanks guys!!!
Old 03-25-2015, 06:19 PM   #12
CamaroDreams76
Here is the ZL1/1LE shifter removed. MGW is a big improvement.
Old 02-11-2017, 05:37 PM   #13
FastGirl
FastGirl's Avatar
Drives: 2013 2LT/RS
Hey if any of you on this thread, want to sell their MGW, sent me a PM, in the market for one :-)
FastGirl is offline   Reply With Quote
Old 08-19-2017, 01:53 AM   #14
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
We're running an MGW group buy for the V6 right now. They went out of production, so this is gonna be the only way to get back on board!
http://www.camaro5.com/forums/showthread.php?t=504933
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
