02-15-2015, 06:14 AM | #1 |
Elite2 CC pictures ZL1
Has anyone installed the Elite 2 CC on the drivers side with a CAI installed, if so, do you have any pictures, I'd love to see how you mounted the can. I was hoping to mount mine on the stud that is not used after taking the stock intake off, there's not a lot of room left now that i see (the heater hose in the way) ?? thanks
JRE 135 RWHP & 93 tune, SCT-4, ATI Superdamper, CAI, Elite2 CC , ID850 injectors, NGK TR7IX
NAPA Green Belt Lingenfelter 9.55” L220290709 (23%) pulley Lingenfelter LPE idler relocation bracket DynaTech SupperMaxx LT headers/Supercats BMR 1" lowering springs BMR toe rods, BMR trailing arms, Z/28 wicker bill extension. HAWK HPS, MRR228's, M/T ET SS's P305/35-20 Last edited by JD-ZL1; 02-15-2015 at 06:14 AM. Reason: mispelled |
02-15-2015, 06:30 AM | #2 |
a better picture under the hood
CAI installed
NAPA Green Belt Lingenfelter 9.55” L220290709 (23%) pulley Lingenfelter LPE idler relocation bracket DynaTech SupperMaxx LT headers/Supercats BMR 1" lowering springs BMR toe rods, BMR trailing arms, Z/28 wicker bill extension. HAWK HPS, MRR228's, M/T ET SS's P305/35-20 |
02-15-2015, 07:15 AM | #3 |
Drives: 14 Camaro ZL1, 87 Grand National Join Date: Sep 2014
Good post! I was wondering the same thing. I saw a post several months ago where someone mounted theirs inside their roto fab cai, which is what I have. Just received my Elite 2 CC but havent been home to install yet. My thought was since you had to unscrew the bottom catch cup off the Elite 2 it would be difficult inside the intake filter housing.
Vengeance Racing + Cat and Muffler Delete > Viagra
02-15-2015, 08:56 AM | #4 | |
I ordered my elite from tyler at JDP Motorsports, with the G8 mounting bracket. he said this is not an uncommon mount for the ZL1. I told him i wanted to use the un-used stud to mount it. However, there is a hose that comes up and goes to the firewall in the way if you try this mount setup. I would think mounting inside of the roto-fab, you would have to take the unit off every time you would empty.. I didnt want to mount it off the radiator bolt in front is the reason i thought I'd do the drivers side setup..
02-15-2015, 11:44 AM | #5 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I have mine mounted in the RotoFab CAI..
I'll snap some shots later on today and post.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
02-15-2015, 12:20 PM | #6 | |
02-15-2015, 12:21 PM | #7 |
02-18-2015, 06:55 AM | #8 |
I worked on this yesterday afternoon and finally decided to use a zip tie to pull the ac line over toward the inner fender panel under where the hot battery cable is located. Then I used a spacer on the mounting stud to get it as high as possible away from the ac hose. I shortened the two 42inch stainless braided hoses approx 8 1/2 inches for a good fit. some are pictures attached.. Most people apparently use the roto fab intake and there must be more room on the one side as opposed to the CAI. I wanted to mount the E2 on the drivers side as opposed to using the front radiator method. Anyway I think its going to work out great.
02-18-2015, 07:30 AM | #9 |
Jim...I put mine on the passenger side because my Lingenfelter intercooler reservoir is mounted on that stud. I used the LS3 bracket and one of the lower bolts that goes to the AC compressor for a solid mount. I've had people ask me if it was a factory location.
02-18-2015, 07:37 AM | #10 |
http://www.flickr.com/photos/8966880...n/photostream/
http://www.flickr.com/photos/8966880...n/photostream/ The bolt size is M10x1.5x105mm which is an alternator bolt in the help section at Advance Auto. The spacer is a 1"x3/8"x1". Hope this helps someone.
02-18-2015, 08:24 AM | #11 |
awesome, thanks Steve. I look forward to seeing your new Z/28. I've had the CC for a while and finally decided to mount it. ttyl
02-18-2015, 01:42 PM | #12 |
Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
Hey JD-ZL1, the E2 has 3 ports you can plug into the catch can right? One for inlet, one for outlet and one other connected to help at WOT... Am I right??? Is there a reason why you are only running 2 ports and not 3? I am really in the fence about ordering this or the Apex
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
02-18-2015, 04:02 PM | #13 |
KaBoom1701
I totally forgot to post the pic I said I would....my bad.
Here they are.
Mods:
02-18-2015, 04:29 PM | #14 | |
Drives: 2010 Camaro Join Date: Nov 2009
That looks nice, that's our G8 Driver's Side mounting bracket. Steve |
