Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Exterior Parts & Accessories
Old 02-05-2015, 03:15 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Now available from SCP: 2010-2013 Camaro Hood Insert by ACS 33-4-095
2010-2013 Camaro SS RS LT Hood insert by ACS
Introducing the TL1 Hood Insert self-install kit, the coolest way to upgrade your STOCK Hood. That's right, modify your Aluminum Hood and save on re-paint and the hassles with replacement hoods. The ACS TL1 Hood Insert self install kit pays homage to the Zl1 while matching the lines of the existent stock hood of your Camaro.
Other than its lightness the original Camaro Hood does not offer any performance advantages, until now that is. Install the Tl1 Hood Insert to extract the engines hot air, and reduce body lift at high speed by relieving under hood pressure. Trim your hood following our guide and templates, rest assured every trimmed edge will be covered (Margin of error, +/- 1/8'' outer). Hood insert kit includes a water management system draining the water towards the front radiator support away from critical engine electronics. For extreme events like racing, you can easily remove the deflector for an optimum suction effect.
Insert is made in ACS's proprietary RTM process and is shipped in a primer finish ready for prep and paint. Unlike conventional fiberglass ACS's RTM process has been tested to withstand heat and distortion. Stock hood will need to be trimmed and 6 mounting holes will need to be drilled. Includes the Insert, rain water deflector, mounting hardware, octagonal grill mesh kit powder coated black and templates.
Reduce body lift and engine heat by upgrading your Camaro Hood while saving on repainting or heavy cost associated with replacement hoods.
Order here: Camaro ACS Hood Insert
southerncarparts is offline   Reply With Quote
Old 02-08-2015, 11:48 PM   #2
stealth_grey12
stealth_grey12's Avatar
Drives: 2012 V6 1LT RS
Has anyone seen this in person yet? It looks like it sticks up quite a bit. Is it that noticeable or dramatically different from the actual zl insert?
stealth_grey12 is offline   Reply With Quote
Old 04-18-2023, 01:13 AM   #3
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...rt-p-6730.html
