Old 01-26-2015, 12:36 PM   #1
route66
Drives: 66 coupe 78 pace car 2014 coupe
Mobil 1 Fill Cap
Does anyone know the GM part number for the oil fill cap with the Mobile 1 oil call out for the C7 ?
Non Z51 car, has wet sump oil system. Thanks OldJedi for the response.
route66 is offline   Reply With Quote
Old 01-26-2015, 10:05 PM   #2
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
There are two cap numbers. With and without dry sump oil system.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 01-27-2015, 09:08 AM   #3
Corvette7Tuning
Drives: 2014 corvette stingray
Check with the dealer. They should be able to supply that.
2014 Corvette Stingray Parts & Accessories
Lowest Prices & Free Shipping!
www.Corvette7Tuning.com
Corvette7Tuning is offline   Reply With Quote
Old 01-28-2015, 12:40 PM   #4
route66
The Answer
I now have the answer to my posted question for a oil fill cap for the non Z51 engine that says Mobile 1 and why there is so much confusion. THERE ISN'T ONE THAT SAYS MOBILE 1 from GM at this time.
Old 02-20-2015, 07:36 PM   #5
OldJedi
Use the Force
OldJedi's Avatar
Did you check with some owners from 2006 or so to see if their caps say Mobil1and fit your car.
Old 02-22-2015, 10:31 AM   #6
lamjoh
lamjoh's Avatar
Drives: 2015 Torch Red Z51 2LT
http://www.corvettemods.com/C7-Corve...s-_p_9915.html
Torch Red Z51 Coupe 2lt, Blk Interior, 8spd Auto, MagRide, Alum Blk Wheels, Red Calipers, Carbon badges, Transparent roof
(1100) Ordered 09/25/2014
(3000) Accepted by Production 09/30/2014
(3300) Scheduled 10/10/2014
(3400) Broadcast 10/17/2014
(3800) Produced BORN 10/28/2014
(4B00) Bayed 10/29/2014
(4000) Available to ship 10/29/2014
(4200) SHIPPED 11/03/2014
(5000) Delivered 11/04/2014
lamjoh is offline   Reply With Quote
Old 02-23-2015, 09:42 AM   #7
route66
Yes I know there are aftermarket ones made usually to match engine dress up kits. I was looking for something that looks stock or is from GM as my post states. GM does not make one. Thanks though for the input.
Old 02-24-2015, 12:00 AM   #8
Joe Stingray
Joe Stingray's Avatar
Drives: 2019 Stingray 2LT
actually the cap you seek has been used in many applications within the GM house (Chevy, Buick, Caddy....etc) until I can lay my hands on a C7 non-z51 to verify the fit, but it can be found for less then $10. even at GMPARTSDIRECT.com, Amazon, and Ebay. but just by looking at the images. this will work.
GM P/N 12577268 (the current cap with dexos on it is 12643759)
Name:  OIL CAP TOP.jpg
Size:  15.6 KB Name:  OIL CAP BOTTOM.jpg
Joe Stingray is offline   Reply With Quote
Old 02-24-2015, 08:36 AM   #9
lamjoh
lamjoh's Avatar
Attachment 696779 Attachment 696780
will this fit a 2015 Z-51?
Old 02-24-2015, 08:47 AM   #10
Joe Stingray
I am told that the Z51 caps and the NON-Z51 caps are different sizes, but I can not verify that at this time. in fact I can't HONESTLY say that for sure this cap will fit the NON-Z51 cars, until I lay my hands on one.
if they cap you are looking at above LOOKs like the Z51 cap? I can tell you this cap is a 90° twist lock cap.....and the bottom side is 1-3/8" to 1-7/16th in. diameter.
Old 02-24-2015, 09:35 AM   #11
Joe Stingray
did a little more digging and found another part number, 12593356, and in the GM OUTLET PARTS site, it specifically shows that it fits the 2014 Z51 Stingray.
at the top above the pic of the part is a " Make sure this part fits your car " link and when you drill down is shows it fits.
http://www.gmoutletparts.com/oe-gm/1...h_str=12593356
Name:  mobil1 oil cap.jpg
AND according to the description, that cap is the same one that came on the 5th Gen Camaro SS's, so if you know someone that has a SS Camaro. check out their car and see if their cap will fit your Z51 oil tank and report back.
Old 02-24-2015, 11:03 AM   #12
Joe Stingray
I just had a buddy stop by, he has a Camaro SS.....so we popped the hood on his car, and my Caddy (3.6L D.I) and both caps are IDENTICAL in shape and fit.....so the final true test would be to go by the dealership OR find someone that has a Z51 and compare the two......if they are the same.....its a done deal and the part number above (12593356) will fit and have the MOBIL1 logo and print on it. The one in post #8 (12577268) will work as well, the only difference is the shape of the top.
Old 02-24-2015, 12:56 PM   #13
route66
I checked both out on the GM Outlet site and they both show for a Z51 and I would think if they fit both Z51 and non Z51 models it would show application for both not just Z51. So if anyone finds out they are both the same please post and the question is answered.
Old 02-24-2015, 06:30 PM   #14
lamjoh
lamjoh's Avatar
do you have a link for where you seen it said for Z51
