Old 11-22-2014, 11:42 AM   #1
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
GM now wants z51 cars oil changed at 500
Old 11-22-2014, 11:48 AM   #2
stratosphere
stratosphere's Avatar
Drives: 2015 Stingray & 2011 Cruze
WoW interesting! Thanks (455 miles here)
stratosphere is offline   Reply With Quote
Old 11-22-2014, 01:00 PM   #3
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Just some common sense says its not the oil burp problem as that would be handled with a "check the level" bulletin, I can only think it has to do with the recent failures, and the oil being contaminated or carrying mfr debris from the added Z51 components......can't be much else....
Old 11-22-2014, 04:37 PM   #4
NC C7
NC C7's Avatar
Drives: 2014 CRT C7
Here's another thought on when to change your oil. My car is a non Z51 and I changed my own oil when it turned 1000 miles. I was really surprised at how dark (black) the oil was with such a short run time. On my other vehicles I change at every 5000 and the Vette's oil looked every bit as bad as those do after much more mileage. I didn't use a magnet to check for metal or have any way to test for contaminants but the oil looked plenty dirty. I'm glad I didn't wait any longer before making the first change. Also you may want to take a look at your brake resevoir. At only a couple hundred miles I looked inside mine and it had some dirt-trash laying in the bottom. My dealer fished it out and said if it showed up again they would need to flush the system. Just something to think about,hope it helps
NC C7 is offline   Reply With Quote
Old 11-22-2014, 05:26 PM   #5
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
the oil on a lot of new engines turn black quicker than earlier gens, don't know why but I think it's that they run hotter than prev gens...its normal..in a turbo engine it goes black within 300 miles!
Old 11-22-2014, 07:07 PM   #6
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Thanks Glen, mine turned 500 miles last week. I will take it in this week.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 11-22-2014, 07:33 PM   #7
RottenII
RottenII's Avatar
Drives: 2014 C7 1LT Z51
Had mine changed at 900 miles. Glad I did.
RottenII is offline   Reply With Quote
Old 11-23-2014, 01:37 AM   #8
C7Driver
C7Driver's Avatar
Drives: 2014 Z51 Lime Rock Green
This info comes a little late for me as I just did my first (Z51) oil change at 5,610 miles. However, I did change out the oil filter in August when I had less than 2,000 miles on the odometer.
C7Driver is offline   Reply With Quote
Old 11-24-2014, 08:51 AM   #9
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
the bulletin is out, lot of blah blah blah but here's the reason:
Some 2014/2015 Z51 and Z06 Corvettes may experience a condition that leads to oil leaking out from the air cleaner assembly. This condition may be caused by running the engine continuously at a high engine speed with the first factory fill oil, resulting in silicone sealants in the engine’s gaskets degrading the oil’s anti-foaming agents. The oil foam has no effect on the engine’s durability.
Old 11-25-2014, 10:58 AM   #10
Bulos
Bulos's Avatar
Drives: 2015 Z51 2LT CRM & 2006 Scion TC
Thanks Glen this puts it in perspective. I called the service manager at Phil Smith in Plantation, Fl. and read what I had here to him he had no notifications about this nor does my VIN indicate any sort of recall but in his words "if it was my car I'd bring it in for a oil/filter change it will be covered by the warranty" Bought it in this morning, they changed the oil and filter and added a service to my freebies.
Bulos is offline   Reply With Quote
Old 11-27-2014, 07:27 PM   #11
stratosphere
Hit 500+ miles today and have appt to get first oil change tomorrow morn.
Old 12-04-2014, 12:03 PM   #12
BigEastVette
BigEastVette's Avatar
Drives: 2017 Z06 3LZ BLACK ROSE, FORD F250
I hit a little over 1000 on a trip to Houston for Thanksgiving, took it in on Tuesday right after reading this post, service Mgr said they had not been notified of this from GM but better safe to change out the break in oil and get the Mobile 1 full synthetic in there.
I spoke to my buddy who has a Z51 convertible and he said that he had seen an article where GM said that all the current cars coming off the line would not have a break in oil, only full synthetic ..........??
BigEastVette is offline   Reply With Quote
Old 12-04-2014, 01:30 PM   #13
fire chief
fire chief's Avatar
Drives: cyber gray 2lt
Does GM recommend synthetic oil for the (2014) Z51? When mine went to dealer service they did not use it.
fire chief is offline   Reply With Quote
Old 12-04-2014, 03:32 PM   #14
BigEastVette
my dealer told me, Mobile One Full Synthetic ONLY !!
