10-28-2014, 02:42 PM | #1 |
Drives: 2011 Camaro 2ss M6 Join Date: Mar 2012
Need help changing toe inches into degrees
I'm having problems where I got my car aligned that they can't switch inches to degrees. What is 3/32" in degrees?
10-28-2014, 03:21 PM | #2 |
This is the alignment they put on my car
10-28-2014, 03:44 PM | #3 |
Toe is not measured in degrees. Only caster and camber are measured in degrees. Never seen an option on an alignment machine for degrees of toe. Only fraction or decimal readout.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
10-28-2014, 04:38 PM | #4 |
This is what I was given.
10-28-2014, 06:17 PM | #5 |
Ok. Well i have to figure out why in 1100 miles after installing them they are almost gone. And I installed a clutch 550 miles ago so I know for sure more than half of it is not hard at all
10-28-2014, 06:21 PM | #6 |
And my rear end gets really squirrelly when hitting bumps?
10-29-2014, 10:28 PM | #7 |
Drives: 2004 Chevy S10 Crew Cab Join Date: Jun 2009
The squirrely ness probably occurs due to losing traction when hitting the bump and the torque hitting the pavement again.
Future Camaro: 2SS, Red Jewel Tint, White Rally Stripe |
11-02-2014, 06:27 PM | #8 |
'It's an experiment'
Just for reference (for both) in case someone wants the other:
http://robrobinette.com/ConvertToeDegreesToInches.htm http://robrobinette.com/ConvertToeInchesToDegrees.htm -Don |
11-02-2014, 09:37 PM | #9 |
This is with just 1300 miles on the tires. Nitto invos
11-02-2014, 09:39 PM | #10 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
Jesus.. they bald ! 1300 miles of burnouts?
11-02-2014, 09:39 PM | #11 |
So after arguing with the alignment shop they finally bought me two back tires and did the alignment how it should be done.
11-02-2014, 09:41 PM | #12 |
